Marina Instrument Question
  • Marina Instrument Question
    Can anyone help me with a quick question - I have a two instrument ( speed + petrol/temp ) Marina instrument panel that I am fitting into a new dash. I am fitting coloured warning lights, but unfortunatley have lost track of what light is what function. Can anyone tell me what the function of the light on the left right and top and bottom are - need to fit the lights before wiring it all back up !!
    Many thanks in advance
    Re: Marina Instrument Question
    Andy, the easiest way is by wiring colour codes,i.e. blue/white headlamps yellow/brown charging light etc I have a print out of a Marina wiring diagram as per Marina handbook if it will help.
      Thanks Phil, but not sure the wiring codes help much as the bulbs plug into the "circuit board" on the instrument itself. I just need to put correct coloured "lens" in front of each position. Hopefully someone with a marina instrument cluster can tell me which light is in which position on it - for example is main beam at top or bottom etc.
      Attached a couple of pictures of my dash making efforts - aluminium front with ply backing - the lights themselves are small 12v LEDs from Maplin Electronics - should save me changing bulbs :-)
        Andy, just had a look at my Marina, top light (inbetween gauges) BLUE main beam warning light. Bottom left ORANGE oil warning light. Middle bottom GREEN indicators, and bottom right RED ignition warning light, hope this helps
          Brilliant - thanks for that - exactly what I needed to know,
            Andy,
            Where abouts in Bristol do you live. It would be good to get together for a chat and a beer?!
