Marina instument panel
  • Marina instument panel
    Ok, this is the first time of trying to fit a marina instrument panel to the Marlin.
    Questions;
    1)Do I need a voltage stabiliser as this will be wired to 1980's Toyota Corolla wiring loom which didn't have one for the original instruments.
    2) There is an oblong angled space which looks like it should have a connector of some type in it, this I can’t find in the manuals, does anyone have one?
    3) The tacho to the left looks like it has two connectors one to the left and one above another type of connector, now what is the round hole?? Is it some type of vacuum?
    Please help lots of you should have done this, I hope. Look forward to lots of replies. Adrian
    Re: Marina instument panel
    Voltage stabiliser is used on a Marina for Fuel and Temp gauges only. What supply goes to them now?
    The connector is a little important for all the elecctric connections. Possibly ebay, but the marina owners will have one somewhere.
    I have no idea what the tube on the tacho is for.
    What manuals do you have, BL or Haynes. If you can wait a week I can scan and email the BL workshop manual relevant pages.
    PS have you read the last email I sent you. It might help you out.
      Hi Steve, didn't receive anything from you.
      Thanks for the offer I already have the workshop manual and also the parts manual and it isn’t clear in either. I also have the Haynes one but still not clear.
      I am just trying to suss the Toyota's wiring diagram, this is always the problem with mix and match cars.
      As I am finding it hard to get onto the Marina Owners is there any way you could broker a request to see if anyone has the connector it would be a great help.
        See my latest post in misc
          The voltage regulator plugs directly onto the back of the instrument panel. See the three slots with the little screws beside them? at the bottom just right of middle, it goes there. The gauges wont work at all without it as there will be a break in the circuit.
          As for the tacho, the manual shows two hoses connected to the tacho unit; a push on one to the top ridged tube and a push-in one going into the larger lower one. What they are for I cannot tell.
          I remember the plug that went into the oblong hole, it was an "insulation displacement" type fitting with all the wiring loom wires clipped into it, to make the contacts with the flexible printed circuit board, via springy bronze contacts on either sise. I very much doubt that they can be obtained new now,
            But if you can find a classic 80's Mini with a 3-clock instrument binnacle behind the steering column (rather than the central clock) the plastic plug on that "may" be compatible...
            I did wonder if a new classic Mini loom comes with this plug (so you could track one down from the supplier) but the Mini Spares website explicitly says to use the old plug...
              This doesn't help I know but when I built my roadster (PKK989M) I traced the Marina circuit board and mapped them onto some Smiths instruments, from a Triumph I think. But I also recall the speedo was out, and I think Clive (current owner) says it still is.
                Adrian,
                Assume it was you who dived under my dashboard yesterday morning. I hadn't spotted your query before so, in an attempt to provide further assistance, I had a closer look this evening.
                There are 2 connections to the rev counter, 1 male, 1 female.
                According to the car specific wiring diagram I inherited, the male one is connected to the +ve side of the coil.
                The female one is connected to the fused side of the permanent supply.
                Jim
                  All, Many thanks for all your many comments and suggestions. Jez you were spot on and I contacted a company called Wood and Pickett today and spoke to a very nice helpful guy who said 1) that they were the same on the Mini as the Marina and 2) he had loads of mini wiring looms in a shed which were not all complete but would find me one and I could have it for £5 plus £1 P&P. Now that’s what I call a bargain. Along with the assistance from Jim I can now go ahead and fit it with confidence. Adrian
                    Excellent news - and at a fiver that loom will be a cheap source of wire. Tempted to phone up and get one myself.
                      Well it got delivered, it is the same, it fits, happy days.
                          Hi Adrian,
                          just solved the forever the problem. Please have a look on e bay nr.130575501085 solid voltage stabilizer - 3 wires negative hearth, positive, gauges ( fuel, temperature)
                          Hope this can be usefull
                          Ciao to everybody
                          The only Marliner in Rome
                          roberto
