Marina Roadster 1.8TC Q67 GJA
  • #31
    Re: Marina Roadster 1.8TC Q67 GJA
    You look fully trolleyed, ventured into workshop to look at things and lasted about an hour.
    • #32
      I managed to loosen the bottom hose on the radiator enough to drain a few litres and top up with fresh anti-freeze, run till hot, by then had enough, too cold. Will have to go back later to check levels and top hop though.
      • #33
        Good to see that you take the gnome out of the garden over winter. David
        • #34
          Only needs a fishing rod in his hand - he's already got the silly grin!!
          • #35
            Visible progress, I've put new shells in the big ends and mains, pistons are all OK. Need to work on an idea for the bulkhead stiffener, maybe from the A pillar to the bulkhead ?
            Then give the engine a bit of head and add the other ancilliaries
            • #36
              And you said mine was a neat job, yours looks wonderful. Keep up the good work.
              • #37
                Always looks better in the pictures rather than reality, but thanks anyway Adrian.
                One month on, slow progress, but it certainly won't make Stoneleigh this year !
                • #38
                  Hey DC looking at the rear end pics - why are the shocks upside down ???
                  • #39
                    ..........................cos that's the way they were Lol
                    Seriously (see post #25 pic)there's an eyed bushed end, and t'other end has a single threaded rod with two rubber donuts , nuts and locknuts which attaches to the spring plate.....it's the only way they fit !
                    However, another thing I've noticed today - I put the prop shaft back in as it came out with the sliding bit to the front - the build manual says it should be at the back.
                    Dunno why, but I guess someone will know better than me.
                    • #40
                      Methinks someone ordered new dampers & didn't spec which end out of stem & eye should be which.
                      • #41
                        I reckon they must be the export variant for the Australian market!
                        • #42
                          The problem with those shocks that way, is all the water and dirt will collect in the bottom and rust the damper tube shaft me thinks ???
                          • #43
                            You're so right Baz. The original builder covered them, so I've done the same, and it had worked because these are the "reclaimed" original shocks.
                            • #44
                              Nice one DC !!!
                              • #45
                                Also all racing motor bikes have upside down fork dampers !!
