SU Carb Refurbishment
  • #16
    Re: SU Carb Refurbishment
    Hi I have fitted a 2.0 zetec to my roadster if I can be any help please ask. It is running a standard rear axle and frount brakes but have put green stuff pads on the frount. The engine is running on bike carbs which I bought from Danst engineering and a nodiz ecu it's not that complicated to do, probably the hardest part is welding in new engine mounts in.
    I will put some pictures up if you are intrested
    Regards Angus
    • #17
      Regards Angus
      Could make a good article for pit stop.
      • #18
        Regards Angus
        Yes pictures would be great thanks
        • #19
          Hopefully a couple of photos attached
          • #20
            Thanks Angus, its still a tight squeeze on the induction side with bike carbs. i want to go fuel injection and talking to the guys at the Scottish Kit Car Center they use the standard single throttle body, standard ECU and a custom inlet plenum like this one they are doing in another car right now.
            How about your sump, what happened at that end of the build?
            • #21
              That looks really good, yes I think the custom pelenum and keeping the throttle body looks good and may have saved me a lot of time as the carbs on mine fouled the stering which I altered then it led me to relocate the servo. Replacing the servo and brake master cylinder was not a big deal for me as the originals where Brocken.
              looking back I should have gone down this route but I had bought the carbs so I was going to make them fit!
              Regarding the sump I chopped the metal section of the sump down and added a couple of baffles I followed a lot of the hints and tips on pauls Zetec installation, type it into Google and his page should pop up.
              • #22
                Hi Scott,
                Yes I probably should wright it up but my engineering skills come know where near as good as yours! when I get time I will, but time is not on my side at the moment running a business and having a young family take up a lot of my time.
                • #23
                  What gearbox did you use? I assume a Type 9?
                  I am thinking Mazda RX8 gearbox
                  • #24
                    Well an upgraded engine and box will have to wait for now, so its off with the Old and on with the New Carb. Ready for cables and a tune, but only after the clutch is done.
