Re: Marina rear brake bleed problem...
QUOTE "the valve that the pipes go to from the master cylinder and then go off to the front and the rear was jammed.
This device is actually a pressure differential warning actuator when one of the circuits looses pressure the shuttle moves across and actuates a switch in the middle.
Once you repair the leaking side you have to carefully bleed the opposite end to reset the shuttle.
