Roadster Front suspension parts req'd
  • Roadster Front suspension parts req'd
    Hi All
    I am looking for a marina front suspension arm that fits on the l/h torsion bar
    Need both parts ( metal and cast ) as i have damaged one on my car
    If you can help please message me or call 07933 380222
    Happy to pay going rate
    Many Thanks
    Re: Roadster Front suspension parts req'd
    Not sure quite what damage you have done, but the usual failure is corrosion between the upright and the trunnion.
    It is possible to fit a Walford trunnion that cuts its own thread.
    As I am currently (allegedly) not an MOC member, it's lucky I can post this advice.
      I may have misunderstood can you identify the parts
      here or there
      It may be that part 37 has been twisted as a part of accident damaged, as identified on other incidents.
        Hi Steve ,
        it's the arm that's attaches to the torsion bar that the upright bolts too, as i have bent mine
        thanks Mark
          Mark
          Try this pic, is it the passenger side you are talking about ? I probably have used spares for both sides anyway
          E mail the info on exactly which bits you need to me at home, my details are in Pitstop
          Dave Cunnington
            This is drivers side , also from the front, before hub etc goes on. It maybe easier for you to see the parts detail in this pic
              Hi,
              thanks for for the photo
              its the lower arm arm that attaches to the torsion bar and comes out to meet the front upright and is connected with a trunion
              it's 2 parts that bolts together
              many thanks Mark
                Here is a start,but ouch at that price.
                  Mark, as per post #5, get in touch if you want help
                  I don't know if they are handed, so which side of the car is it...............................and I shall need your address to send the items
                    The only parts that are handed on the front suspension, according to the parts list are:
                    Item 37 Pin and stub shaft swivel/Steering, suspension upright
                    Item 45 Trunnion/Lower Swivel pin
                    Item 60 Steering Lever
                    I reiterate, if the lower arm assembly has been accident damaged, Items 1 and 2, I would suspect that the Steering suspension upright may also be twisted.
                      Thanks Dave that's great regards Mark
