Cabrio windscreen
    Re: Cabrio windscreen
    One of each to help the decision process ??????
      Any clues an where to get the windscreen from mine has a crack in it but the new one needs an emark to get through IVA
        Find a small, independent, keen and intelligent windscreen installer. That is the hardest part.
        A new Cabrio screen can be cut from a Landover windscreen in such a way as to keep the markings. Use the old screen as a template. The latest bonding techniques use specialist equipment to apply the “glue”. Your installer may insist on installing it for you, which is probably a good thing. Modern cars use the windscreen as a structural component. When fitting mine the installer gave me some “paint” which he called primer, with an oversized cotton bud, that allowed me to paint the outer edge of the screen prior to installation.
        Best of luck,
        PS: You don’t say if you need to remove the old screen. Ask here for more tips if you do.
          Hi Paul
          Thank you for that very useful information I have already removed the damaged screen so ok on that thank you
          I will do some research locally and find someone who is prepared to cut the Land rover one I have read the notes elsewhere on fitting and will probably try the CBS gunge
          but as you say the the committee is still out on that one
          Kind regards
          Nigel
            Hi Nigel
            Where are you ?, I know someone in Stoke On Trent who I think would be able to do the job
            Dave
              Hi Dave
              Thank you for your message we are in Godstone Surrey
              Do they have a southern branch ??
              Thank you again
              Nigel
                Hi Nigel
                Sadly not only does close to Stoke On Trent preference is to do at his premises happy to help with oddball jobs and older cars.
                Not so many left like him
                Dave
                  Hi Dave
                  Thank you again
                  Nigel
                  Nigel,
                  I had a new windscreen cut and fitted to my Sportster by http://oldschoolwindscreens.co.uk/. They are in Chertsey, so not to far from you.
                  They mostly do ordinary tin tops but the boss specialises in hand cut screens for classic cars, etc.
                  Very knowledgeable and sorted me out.
                  Peter
                    Thank you very much for that Peter I will give them a ring
                    Nigel
