Engine fan
    Re: Engine fan
    This is my MK IV Air Flow Detector (AFD) it is surprisingly good at showing air flow. After putting Millie through her SVA I discovered the demist fan was connected the wrong way round. Fortunately, the inspector only used his fingers to detect air movement. In case you can’t guess it’s a bit of tissue paper sticky taped to a stick. It will even give you an indication of smooth flow or turbulence.
      Re: Engine fan
      I love hi-tech solutions Paul. Can I buy one off e bay??? Lol!
        Re: Engine fan
        I wonder what MKs I-III comprised..?
          Re: Engine fan
          Well! I can report that the fan now works. There's a positive gale blowing in there! So well, in fact, that when I stand alongside the car with the bonnet open and give the engine a rev my hair blows (well, what's left of it...) in the wind! It's like one of those shampoo ads! Even my beer tastes better!
          The weird thing is, putting it back together I found that the bolts fouled the water pump webbing meaning the bolts were never tightened fully for years even though the pully didn't wobble. Correct length bolts used and all seems well.
          Yay, roll on summer!
          Gareth.
            Re: Engine fan
            Mk 1 Wet finger held in air stream
            Mk2 Talc powder in air stream
            Mk 3 Shreds of tissue from cleaning off talc mess
            Mk 4 Eureka!
              Re: Engine fan
              Just a thought, whilst there's a couple of pictures of mine on this thread...is it possible to those in the know, to identify if I have a mk1 or mk2 steering rack.
              Just curious.
              Cheers Gareth.
                Re: Engine fan
                Hi Gareth,
                mk2 I'd say, due to flange visible at steering knuckle end and lack of flange on opposite end.
                Derek
                Stumbling around in the dark
                Marina based SWB roadster
                  Re: Engine fan
                  Originally posted by Blue Marlin View Post
                  Hi Gareth,
                  Derek
                  Inevitably all the information you need to spot the type of rack is here
                  Log into your KeepandShare account with your account name and password.
                    Re: Engine fan
                    Mk 4 Eureka!
                    5. Elastoplast for when finger makes contact with a moving fan.
                      Re: Engine fan
                      As has been said your fan is on the wrong way round, but it will still push air the right way as it is . Just not efficiently. I have had a person tell me that I the fan is turned around it will blow instead of suck. It wasn't April the 1st.
                        Re: Engine fan
                        Yep! A common misunderstanding. If you take a right hand thread bolt and turn it around it is still a right hand thread bolt! Simples!
                          Re: Engine fan
                          All I can say is, with the fan the correct way round the difference is more than considerable.
                          Hope to see you all at Stoneleigh. The way the fan is performing now, I should be there 10 minutes after leaving Chester!!!
                          Gareth.
                            Re: Engine fan
                            turbo air blower power it is then!! ; - ))
                            • #29
                              Re: Engine fan
                              Well, I took the Roadster out for a proper drive today, not hanging around, up to the Horseshoe Pass to test out the fan, and although it was cold, the temp gauge was reading half of what it normally did.
                              Some decent engine cooling at last, or the gauge is buggered!
                              Gareth.
