Wind deflector friction hinge screws
  • Wind deflector friction hinge screws
    I've got some friction hinges to fit some wind deflectors and I was wondering what length screws others have used to bolt them to the screen frame.
    Re: Wind deflector friction hinge screws
    I recently put mine back on and found one of the screws would not come out, allen key head 'turned' & had to cut a slot in the head with a slitting blade & get a screwdriver in it & a pair of moles... The screws were all about 12mm / 1/2" long, the actual frame is only maybe 3mm thick. I will replace all mine with hexagonal head screws so I can use a socket on them...
      be careful where you drill
        Hence the question
        I was thinking of putting the hinges on the outer surface toward the rear of the frame to avoid drilling into the glass.
          Glad my holes were already there...
            yep, when I did my wing mirrors I cracked the windscreen. it was only then did I find how close the glass was to the frame.
            Be very, very, very careful.
              Indeed, PO cracked the screen on drivers side. Not too bad YET
              Stumbling around in the dark
              Marina based SWB roadster
                It's not just drilling the holes, even the load applied by a tap screwed in too hard in a correctly drilled hole can induce cracking, just the same as a screw that is too long. It does not have to go through the box, simply apply pressure to the face nearest the screen.
                  Looking at Ben's sketch I would be drilling into the VOID parallel with the screen, is that still risky?
                    I was trying to illustrate a three stage process, drill, tap, screw. If each is taken with care and a knowledge it should be OK, but as others have illustrated it's comparatively easy to make mistakes.
                    Parralell to the screen (I didn't pick that up from your post) should be fine.
                      Cool, Thanks. I knew there was an opportunity to make up the spare room for Mr Cockup which I why I was asking
                        Is there is a void..?
                        My brackets are screwed to the front face of the screen rail & I certainly didn't encounter a void when drilling them...though I didn't go too deep for obvious reasons.
                        There are at least 3 variations of Roadster screen & 2 or more variations of screen rail...without bodging more holes in it (I've done 2 screen replacements & have no desire for a 3rd) my screen rail looks & feels like solid, milled bar to me.
                        Happy to be proved wrong but in the end just be careful..!
                          Fitted the driver's side wind deflector.
                          I must have measured it 15 times before drilling the first hole
                            1994 YKC Roadster is a solid MS bar with a milled slot for the windscreen
                              My frame is solid as well. Just finished fitting the passenger side one so it's all finished now... phew!
