colector
  • colector
    Hello
    can we install a carburetor su hs4 on this colector?
    Re: colector
    There are two different types of fitment for the HS4 the one with two holes would fit but not knowing the diameter of the connecting hole the air flow may be resticted.
    Can I ask to what engine you are connecting this manifold to, 'A' or 'B' series?
    If 'A' series then why not fit an Hif6 or 44 which is a superior carb and will give the 'A' series a little boost in the bhp stakes.
    It also has other plus points in that the float bowl is below the carb and has a very good heat sync plate.
    I have included a picture of mine so you can see the fitted version.
      Re: colector
      my colector morris marina 1300
        Re: colector
        Are they called colector in France?
        Your manifold has the 4 stud carb mounting and the hs4 carb has the 2 diagonal studs and 1.5” bore. If your manifold has the 1.75” bore you may run the risk of leaks and a lean fuel mixture, that is if the studs line up.
          Re: colector
          That's the 'A' Series, then I would go with the hif su carb around £70. Make sure you replace the needle with a bdl from Burlan around £12.
          It will run fine and as I said will give you extra BHP for very little outlay.
            Re: colector
            [QUOTE=meverett;44831]Are they called colector in France?
            le collecteur d'admission et d' échappement.
              Re: colector
              You cunning linguist
                Re: colector
                Another option is to carefully cut away the inlet part of the combined manifold (or collector) just leaving the exhaust part intact. Then you can fit a water heated inlet manifold to take a bigger (e.g. 3/4") SU carb. This was a common modification done by old Mini owners and I'm sure the inlet manifold is probably still available. I did this mod to my 'A' series engine back in the early '90s and it worked a treat. It also enables you to fit a LCB (long centre branch) exhaust manifold if you wish although I never got round to that.
                  Re: colector
                  Or
                  Vous linguiste rusé
                  Good old Google translate
                    Re: colector
                    I have the same coletteur as on the images
                    I am looking for a new
                      Re: colector
                      "take a bigger (e.g. 3/4") SU carb" ??
                      Did you mean a 1 &3/4" carb (1.75") as the other carbs are either 1 & 1/4" or 1 &1/2"?
                      Agreed , the 1 & 3/4" SU carb worked well on the A series
                        Re: colector
                        Yes, I meant a 1 & 3/4" (1.75") carb. Brain and finger not working well together! Using a single carb avoids the balancing issues with a twin carb set-up.
