TRW SFK08 rear brake kit
  • TRW SFK08 rear brake kit
    Hi, was planning to fit some new brake springs etc to my Roadster. I chose these and my problem is obvious. Has anyone tried to fit these? I have a 1.8 axle with self adjusters. The shoes say MK2 on them.
    Derek
    Stumbling around in the dark
    Marina based SWB roadster
    Re: TRW SFK08 rear brake kit
    Originally posted by Blue Marlin View Post
    [ATTACH]9994[/ATTACH]
    Derek
    I had a similar issue and I documented the rear break rebuild on here a year or so back so you maybe lucky I may have details my findings. Will try and find the thread later. But yes, there are various types out there!
      For auto adjust brakes the part numbers are the spring at the wheel cylinder is part number 37H 6140
      auto adj end is part number 37H6141
      I suspect the springs you have been supplied with are for manual adjuster brakes.
      Another possible source would be Triumph Dolomite18/50 or late GT6 Mk3 with auto adjusters.
        Thanks for that guys. I'll be sending them back for a refund. I'll stick to the proper suppliers now, a lot less hassle
