Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 43
Thread: Trials Marlins
  1. #31
    May 2018
    14
    Re: Trials Marlins
    The marlin I run is a long wheelbase model we have modified the steering arms (shortened by 1inch)to tighten the turning circle which has made a big difference on some of the tighter sections
  2. #32
    SE London
    2,075
    Re: Trials Marlins
    Are you allowed a knob on the steering wheel I assume twiddle brakes are a no no??
  3. #33
    administrator Club Member
    330
    Re: Trials Marlins
    Just to say on behalf of the silent majority I am very much enjoying this thread.
    May 2018
    14
    Re: Trials Marlins
    Yes you can have a knob on the steering wheel the fiddler brakes are used on classic(sporting) trials car not on production car trials car
  5. #35
    May 2016
    35
    Re: Trials Marlins
    With regard to improving steering response on a MK2 Roadster, fitting a 10" steering wheel improves things a lot and the steering isn't noticeably heavier as a consequence.
    Doing this mod has an added bonus resulting in more leg room which helps get on and off the brake pedal more easily.
  6. #36
    Suffolk
    312
    Re: Trials Marlins
    Like Milliemarlin I also find this thread interesting. Excuse my ignorance but what are fiddler brakes? Speaking as magazine editor it has been a long while since I had anything on Marlins in trials so some sort of article would be great, whether it be a report on a trial or something technical regarding the cars them selves. Something to think about?
  7. #37
    Moderator Club Member
    Derby
    1,347
    Re: Trials Marlins
    I believe that they are individual hand brakes allowing the driver to 'lock' a spinning wheel so allowing drive to be transmitted to the other . Acts like an LSD but only with driver input.
    I'm no expert so if anyone can put me right please go ahead!
  8. #38
    Exeter
    1,092
    Re: Trials Marlins
    The ones that I have seen at The Exeter Trial were on cable operated brakes. There was a separate lever outside the body with no ratchet. Pulling the lever operated the rear brakes and pushing it forward operated the front brakes, using additional cables linked to the brake levers. I believe hydraulic systems use the same principle just with extra master cylinder(s).
  9. #39
    Jun 2015
    Kelsall Chester
    477
    Re: Trials Marlins
    Cheers for that Tony, I know Feb 19 is a bit away yet but I have been on The Fellside website and it doesn't mention geographic locations. I would like to go and see what happens first.
    Dave.
  10. #40
    SE London
    2,075
    Re: Trials Marlins
    Quote Originally Posted by dogoncrazy View Post
    Allowed on some classes of trials car, fiddle brakes is a system of two hand levers that operate the rear brakes independently side to side the art is to know which wheel is spinning.
    http://www.austin7club.org/thetrialscar37.htm
