Do you know much about the Ford i4 8 valve DOHC engine?
  • Do you know much about the Ford i4 8 valve DOHC engine?
    Fitted to many Sierras, both EFi an carburetter. Question...where in the block is the engine temperature sensor...or is elsewhere in the cooling system?
    Re: Do you know much about the Ford i4 8 valve DOHC engine?
    Early Cortina Pimto engine is front left between carb and fan, 2/3 way up the block. Screwed in.
      Look on the bottom side of the back of the thermostat housing, a bit awkward to get to. If two sensors present the other is a separate one for the fan.
      Peter H
        Can't remeber as such but Haynes says "On DOHC
        models, the sender is located at the front of
        the inlet manifold (see illustration)."
