1300 clutch/slave
  • 1300 clutch/slave
    Hi,
    can anyone tell me if the 1300 marina slave clyinder is the same as the 1275 mg midget one?
    also does anyone have a slave cylinder that might work on my car that they might sell?
    also what fluid should I use? is it Dot 4 brake fluid?
    sorry to be a pain
    cheers
    JB
    Re: 1300 clutch/slave
    No its not the same as midget,try your local motor factor for either complete unit or you can get repair kit [new seals] if cylinder bore is ok .Correct on the fluid.JOIN THE CLUB!!!
      You might be interested in coming to meet at Shardlow this Friday around 7.30 onwards.
        yes, I might try and get down on friday.
        Thanks for your help
        JB
          Its proving hard to find a slave cylinder. It appears that the cylinder was exclusive to this model and BL did'nt use it on any other model, is this the case?
          Its interesting.
          I've discovered that a new slave sylinder could cost me ?70! is this about right?
          JB
            Is your's beyond fitting new seals? as that usually works in my experience. Yes It was only fitted to Marina /Ital.Try PASTPARTS on the web or a firm called J.E.M in Leicester on 01455 230626. Can't comment on the price you have been quoted, the last time I purchased a repair kit it was about ?8.Ap Lockeed used to manufacture the cylinder[they now go under the name of Delphi Lockheed or something similair, if all else fails you could try contacting them. Also Lee Hunter is breaking a car so he might be able to help,this is where being in the club is a big bonus! Have you tried Partco in Derby .You can contact me on Derby 753000 for Lee's e mail address
              Thankyou for all your help,
              I'll chase these up!
              My cylinder is siezed solid!
              JB
                Here's a couple more possibles- www.powertrckbrakes.co.uk-www.classic-parts.co.uk
                  I tried all of those contacts with some success, altho I might try that second hand one perhaps, as it might be a quicker option, will ring you
                  Thanks again
                  JB
                    Jon
                    Have you taken the cylinder off the car?
                    Was the car off the road for the winter?
                    You say the cylinder is seized solid-can you push the rod back into the cylinder at all? Please give me a ring since if the answer to the last question is yes then the problem may be elsewhere
                      Message originally posted by: Lee Hunter
                      if you get stuck I have one on a 1700 Marina ....
                      Lee
                        Ebay item number 130102996007
                          Ebay Item number 200101699754
                            Message originally posted by: alex mc aree
                            halfords quoted me 51.00 pounds forclutch slave cylinder for 1979 marina 1300 yesterday.
