Thread: Banging/vibration underneath - could it be propshaft/gearbox?
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11 Re: Banging/vibration underneath - could it be propshaft/gearbox?
    391
    I found the cause of Le Clonk, but had to resort to buying half an hour of hydraulic-hoist time at my local friendly garage. The back of the gearbox had only a tiny gap between it and other chassis-related metal. Also, the engine mountings were passed their Sell-by date. Got some serious mounts from Car Builder Solutions (get their brochure - they have lots of great bits & pieces) for only ?7 each.
    I think the 'clonk' problem occurred whenever the car went over a series of bumps, which caused the engine to bounce up & down like on a trampoline. The rubber mounts were close to marsh-mellow in strength, and couldn't cope. The absence of a decent gap at the rear of the gearbox completed the scenario. Haven't got it all back together, and wont know for sure that it is cured until I do a test on local roads, but am fairly confident it will be OK. Will need to experiment with shims (washers), to obtain reliable gaps in the right places - wish I had a hoist or pit! Not quite the same with trolley-jacks and grovelling up-side-down on a trolley.
  2. #12 Re: Banging/vibration underneath - could it be propshaft/gearbox?
    Jun 2015
    Kelsall Chester
    615
    Just a little reminder that thumping near the back could be the rear spring catching on the seatbelt mounting bolt. It was on mine in Guilisfield, only it hooked on the bolt! Giving me a lean. I cleared it and turned the bolts (both sides) around.
  3. #13 Re: Banging/vibration underneath - could it be propshaft/gearbox?
    3,148
    Take some time to check your UJ’s. Unusual vibration puts them under shock loads for which they were not generally designed.
  1. Propshaft for gearbox swap
    By chrislibby in forum Roadster
    Last Post: 16-02-2019, 03:24 PM
  2. Project for someone - YKC underneath !
    By dcunn in forum SALES:
    Last Post: 07-07-2017, 10:55 AM
  3. Engine/bodywork vibration
    By gouldsborough7 in forum Cabrio / Hunter
    Last Post: 26-09-2011, 09:43 PM
  4. Vibration/judder on braking - any ideas?
    By andy-rogers in forum General Discussion
    Last Post: 28-08-2010, 08:08 AM
  5. steering vibration
    By dogoncrazy in forum Cabrio / Hunter
    Last Post: 19-09-2005, 07:00 PM
