I'm fitting an MGB engine into my marina based roadster. Cant get the spigot bush off the Marina engine whatever way I try. Got the MGB one out though.
The MGB bush has an overall diameter of 29mm.
Thought I had solved the problem by buying a spigot bush QSB 106 off ebay. This has an overall diameter of only 19mm though. On more careful examination the Marina spigot bush seems to be housed in a steel sleeve to bring the overall diameter up to the 29mm reqd to fit it to the MGB/Marina crank.
Have I got the right spigot bush?
Can you buy the steel sleeve to fit the QSB 106 bush into the end of the MGB crank.
Ps still intend to fit a Ford Crossflow engine - this was supposed to be an easy/quick option to use the car whilst I got the Ford parts required!!!!!
