Towbar
  • Towbar
    Hi all
    Could anybody please explain or show me where to fit a tow ball onto my roadster please.
    Also thanks to the people who replied to my earlier post. I wish to fit the tyre onto the boot and after looking at the pictures the boot is recessed for the spare tyre. Has anybody done it on a regular boot before or does it stress the fibreglass to much.
    Thanks Tom
    Re: Towbar
    Hi Tom, the Marlin towball was welded to the rear bumper as a factory option
      Re: Towbar
      Tom
      I had a bolt through one on my roadster with suitably made spacer to match curvature of rear 'bumper'. Towed my sailing dinghy with no problems.
        Re: Towbar
        Tom, regards fitting spare wheel carrier to unreccesed boot, I got some galvanised flat bar 30mmx6mm bent it to curve of boot,bolted one end through bumper other end wasdrilled and 2 short pieces of tubing from a caravan awning bolted on then put 2 of the rubber cups off an awning on bottom to protect bootlid, 2cross pieces bolted on to match centres of stud holes on spare,drilled and 2 bolts put through to locate wheel,we have used ours now for 18 months and no problems hope this helps
          Re: Towbar
          cheers for that everybody. didnt relise it was so easy to do the towbar. Thanks for the info on the spare wheel, luckily my girlfriends dad owns a metal fabricators so should be able to knock something up similar to what was mentioned
