Thread: Marina to Ford Type 9 gearbox conversion.
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11 Re: Marina to Ford Type 9 gearbox conversion.
    3,041
    Thanks for the offer of the box but I am well on the way with this project and too financially comitted to change track.
    I am sure there would be someone else who would like to use it.
    The Ford box will drop in without any change to the tunnel, gives an overdrive and for me more importantly moves the gearstick four inches further back. I dont like the flappy, long gearstick that comes out from the recesses under the dash especially as my seat is pushed as far back as it will go.
  2. #12 Re: Marina to Ford Type 9 gearbox conversion.
    3,041
    Looking good
  3. #13 Re: Marina to Ford Type 9 gearbox conversion.
    3,041
    Waving my own flag (well you have to sometimes) the type 9 box is bolted up into the car and everything works. I just need to sort out the carpet over the transmission tunnel and plug a few of the old holes.
    Well pleased with the drop in revs at speed and the better gearchange, no more flappy levers and closer to hand.
    I had extra adaptor plates made up if anyone wants to follow Jez Cox's original lead, but retain the Marina clutch and bell housing.
  4. #14
    3,041
    The last of the current batch of Type 9 adaptor plates have been sold, so far they have been installed in Marinas, Marlins and Pilgrim Bulldogs.
    We are trying to estimate how many to get made in the next batch. We appreciate that you may not be able to commit right now, but expressions of interest would be appreciated.
  5. #15
    CABRIOBOB's Avatar
    464
    Another option on Ebay.
    MG MGB MGA Morris Minor Conversion Type 9 Recon Gearbox. Item number: 110777485497 www.firstmotion.co.uk
  6. #16
    3,041
    Thanks Bob, thats the beast. you can do the work yourself, and rebuild a Type 9 gearbox, if you have a bench you can lay the parts out on.
    All we have done is make up a plate that sits between a slightly modified Marina bell housing and the Type 9, and work out how to make it all fit in a Marlin or Marina etc using the Marina clutch.
    The MGB boys have done a conversion bell housing for their Type 9 installation but to do that on a Marina you need to fit a complete MGB backplate, starter motor, flywheel and clutch.
    The assembly looks like this.
    I do have a modified bell housing in my garage that I can supply on an exchange basis.
  7. #17 Re: Marina to Ford Type 9 gearbox conversion.
    3,041
    After four years, we have closed down the 5speedmarina website. All sales for the adaptor plates are now through eBay only.
    The first one sold in less than an hour!
    We have limited stock. There are no plans to have any more plates manufactured, this is where the project ends.
    Many thanks to those who have purchased and installed, from Marina based kitcars, not just Marlins, but the Morris Marina community too.
    The difference an overdrive makes is significant, the Marina was essentially designed for 60mph, overdrive makes 70mph driving easy without taking away the fun of the first four gears.
  8. #18 Re: Marina to Ford Type 9 gearbox conversion.
    Dec 2018
    10
    Waking up a very old thread here. Are there any drawings of the adapter plate? So that it might be possible to have a one off manufactured?
  1. Ford Type 9 Gearbox bolted to a Marina engine.
    By stevejgreen in forum Roadster
    Last Post: 16-09-2014, 07:57 PM
  2. type 9 gearbox and marina back axle
    By rooha in forum Roadster
    Last Post: 11-05-2014, 08:47 AM
  3. Cable clutch conversion for Type 9
    By cdow in forum Roadster
    Last Post: 06-07-2008, 11:34 AM
  4. FORD TYPE 9 G/BOX CLUTCH CABLE KIT INFO WANTED.
    By CABRIOBOB in forum Roadster
    Last Post: 28-01-2007, 06:30 AM
  5. Ford type 9 5 speed
    By dogoncrazy in forum Roadster
    Last Post: 01-09-2006, 08:51 PM
