Battery/Starter Cable - Pinto
  • Battery/Starter Cable - Pinto
    Message originally posted by: Joe Ryan
    Can anyone advise me on the Amp. and the Sq mm Section cable that I would need to use on the above.
    Thanks for any help.
    Re: Battery/Starter Cable - Pinto
    Where are you mounting the battery (Bonnet or boot)?
      Message originally posted by: Stefan Carlton
      "boot", don't you mean parcel shelf
      (sorry I'm no electrican so can't help)
        Hi Malc
        Thanks for your reply. I intend placing it against the bulk head under the bonnet in the engine bay.
        Many thanks, Joe
          There are as always many options you pay your money and take your choice:-
          Ratings are for lengths of up to 3 mtrs multi core copper cable, a good source is a welding supply company welding cable is a very good conductor and is very flexible.
          10mm2 100amps, 16mm2 300amps, 25mm2 600 amps.
          quite frankly I would go for the 25mm2 for both live and earth leads from chassis to battery and chassis to engine / gear box.
          Hope this helps
            Hi Malc
            Thanks very much indeed for this information, I find that this will be very helpful to me in the build.
            Once again, many thanks
