fuel filler neck
  • fuel filler neck
    hi all, can some one please post a picture of there fuel filler neck so i can see the angle mine should be at inside and out.
    thanks arf!!
    Re: fuel filler neck
    There are many variations. It will depend what fuel tank you are using, what filler cap you are using, what side is the filler cap to be and is the car Cortina or Sierra based? Did you receive the complimentary magazines sent to you ?
      HI Tim, the car is cortina based and the filler cap is on the near side, the tank, is i think escort van i will try to put some pics up soon as Ive work out how,sorry but now i have not received any complimentary magazines ????? I HOPE THAT THEY HAVE NOT GONE TO NUMBER 6 BECAUSE I WILL NEVER!!!! SEE THEM.
      my address is.
      16st Quintin ave
      barrow in furness
      cumbria la13 9hb
        Hi Arthur
        Your mags are on their way to number 16.
        Sue
          THANKS SUE
            Hi Artyis!
            I have 3 (Cortina with Escort tank) Berlinettas and the filler cap is in slightly different places on all. I can send you som measurements if you wish (pictures are not one of my strengths). The most important thing I have learned (by mistakes) is that the more vertically the filler pipe runs to the tank the sharper the bend on entering the tank and the greater the risk for petrol to be squirted back at you every time you fill up.
            James
              hi James
              all help is good help to me I'm a complete novice,my email address is,arthur_clark(at)btinternet.com
              or home address is,
              arthur clark
              16 st quintin ave
              barrow in furness
              cumbria la13 9hb
              THANKS ARTY.
                HELLO SUE.
                i received the mags today so will get my head stuck in to them and have a good old read.
                THANKS AGAIN for your help
                  just for information - and following on from other threads Arty, if going for IVA, and using an engine with a cat you will need an insert to prevent the wrong fuel nozzle going in - so you can only fit the narrower unleaded nozzle into the pipe. Also, the fuel cap must comply with radius and projections regs, be lockable (mustnt be able to take key out whilst its unlocked) and/or tethered if its not a hinged cap. If recessing the cap into the body work (as I did to overcome the radius problems) then any recess must be capable of draining the excess fuel back into the tank - a funnel shape will work (I DIDNT and will have to redo that bit!).
