Thread: Side Exhaust Pipe
Results 1 to 10 of 37
  1. #1 Side Exhaust Pipe
    2,034
    Message originally posted by: Iain Wilkinson
    I've only recently purchased my Berlinetta and I'm already fed up with the current exhaust banging on the bottom of the car and making my teeth rattle. I'm thinking about fitting a side exhaust as seen on many Roadsters and was wondering if anyone else has carried out a similar modification?
    The main problem, as far as I can see, would be the heat from the exhaust having a detrimental effect (i.e. melting) the runner board, even if I could squeeze some sort of heat shield between them. Do the Roadsters have a greater depth between the bottom of the chassis rail and the runner board which allows them to mount side pipes easily?
    If anyone has fitted a side pipe I would be very grateful if they could provide some advice (pictures if possible, he said, pushing his luck).
    My e-mail address is iain(at)iainandshelly.co.uk.
    Lastly, apologies if this is an old thread, or the subject has been dealt with before, but I've been looking forward to getting a Marlin for a while now and don't want to break it;-)
  2. #2 Re: Side Exhaust Pipe
    North Kernow cliff dweller
    826
    Hi Iain,
    Don't apologise as a lot of the info was in "pitstop" many years ago which you will not have seen. I got my system (for a 2 Litre)Pinto from YKC. They do not think that any heat shield is neccessary and I have had no problems yet. I did wrap the exhaust inside the engine compartment and for about 250mm outside the valance with propriety exhaust wrap. The side exhaust was worth doing as I have left a couple of systems behind on rough kerbs etc. You will suffer from more exhaust noise when cruising though!
    I will try get a photo off tomorrow.
    Cheers.
  3. #3 Re: Side Exhaust Pipe
    2,034
    Hi Dane
    Many thanks for the reply, look forward to seeing the photos. I'll get in touch with YKC see what they can offer and at what price. I think I'll be able to cope with the increased exhaust noise ;-)
    Regards.
    Iain
  4. #4 Re: Side Exhaust Pipe
    2,034
    Message originally posted by: Stefan Carlton
    be careful with putting exhaust wrap on cast iron - it causes heat spots which cause fractures. The stuff to put on cast iron is a "heat blanket" which wraps around the entire header, not the induvidual pipes.
    The Roadster's don't have any heatsheilds as standard.
  5. #5 Re: Side Exhaust Pipe
    826
    Hi Guys,
    I have some grainy pix of the YKC Sidepipe. It is looking a little blued now but does not give a heat problem anywhere else.
    You sre quite correct Stefan, I have not lagged the Sierra Manifold in any way.
    Due to the position of a wiring loom, Brake pipe and coolant pipe, I modded in an extra rail to lift them all to a new position well away from the exhaust and just in case, I lagged the hot pipe as it passes about 200mm below.
    Cheers,
    Dane.
  6. #6 Re: Side Exhaust Pipe
    139
    Oh, And another one.
    Are you all bored yet?
    DC
  7. #7 Re: Side Exhaust Pipe
    2,034
    Many thanks for the advice guys and for taking the time to reply. BTW Dane, did you ever serve in the RAF? I knew a Dane Crosby at RAF Brawdy many years ago.
    Regards.
    Iain
  8. #8 Re: Side Exhaust Pipe
    826
    AArgh .... I have been found out at last.
    Yes Iain, it's me - Brawdy 88 - 92. (was moved on to Boulmer after the 593 incident!)
    I retired last week and now seem to work full time for Cheryl!
    Cheers,
  9. #9 Re: Side Exhaust Pipe
    2,034
    Well well, what a small world. Hope you are enjoying your retirement so far :-) I was released, (escaped), about a year and a half ago. Still, we shouldn't turn this in to a reunion forum, but if you are attending any Marlin type events let me know and maybe we can meet up and swing the lamp ;-) iain(at)iainandshelly.co.uk
    Happy motoring and take it easy.
    Regards.
    Iain
  10. #10 Re: Side Exhaust Pipe
    157
    Hi Dane,
    Just browsing as I have modified my Berlinetta in a similar way and was interested in your radiator expansion tank and winscreen was bottle.
    And for Ian, I glued in some heat shield under the running board, just in case, which now just feels warm.
    Roger
  1. Exhaust pipe positioning
    By element in forum Roadster
    Last Post: 30-03-2017, 06:04 PM
  2. Metro Twin Pipe exhaust
    Last Post: 30-01-2013, 05:32 PM
  3. Exhaust pipe problem on Hunter
    By gouldsborough7 in forum Cabrio / Hunter
    Last Post: 03-06-2011, 01:06 PM
  4. Side exhaust - hello Dane!.
    By amalgamated users from prior forum in forum Berlinetta
    Last Post: 16-10-2007, 05:07 AM
  5. Exhaust front pipe
    By timmacx in forum Roadster
    Last Post: 22-06-2006, 07:09 PM
