Marina based Roadster Data
  • Marina based Roadster Data
    Hi Everyone
    I have seen a number of people over the years trying to find out the Marina Based Roadster Data. Well I have found some facts from a manual I found in the loft:
    Length Overall 136" or 3465mm
    Wheel Base 92" or 2340mm
    Width overall
    Live Axle 60" or 1520mm
    Triumph 56" or 1420mm
    Height to Scuttle 35" or 885mm
    Height to Screen top 45" or 1145mm
    Ground Clearance: designed 7" or 178mm
    : Max. For live axle cars 8.5" or 216mm
    Base of seat to pedals 43" or 1090mm
    Seat Width 15" or 380mm
    Recommended Wheel size 5.5 x 13
    Recommended Tyre size 185/70/13
    Acceptable range of wheel size 4.5 6 x 13, 145/8013 to 205/70/13
    1.3 Marina and 4cyl. Triumph 1440lbs. or 660kg.
    1.8 Marina and 6cyl. Triumph 1570lbs or 715kg.
    I hope this will help someone.
    Re: Marina based Roadster Data
    Are these long or short wheelbase figures?
      Hi Jeremy.
      The figures Adrian has posted are SWB.
      Danny.
        Hi Jeremy, Let me have a look and I will see if I can find the LWB if yiu require it?
          Hi Jeremy, cant find data but my red LWB is 6" longer in the cockpit. I dont think they changed anything else. So the wings and doors are 6"longer that the SWB.
          Hope this helps.
            LWB has 6" greater wheelbase and overall length.
            The extra length is in the cockpit.
            Weights will be a little higher.
            Have a look at http://marlinownersclub.com/forum.php?read=17432&cat=0#n17500
            Hopefully the new website will include this sort of basic data so that non members can look up all variants of Marlins.
              Thanks very much, currently looking for a roadster and was told that the SWB would be too small as I am 6ft 2in tall. Sounds like the LWB will be ok though - just need to find one!
              Cheers
              Jeremy
                Recommend you try to sit in a few Jeremy. Longer legs means higher knees which then hit the steering wheel. A steering wheel can only get so small!
                Enjoy your search.
                Pete.
                  Jeremy,
                  If it helps I am 6 ft and fit into a SWB, admittedly with not much to spare. I suspect girth has as much influence as height!
                  Would be worth a trip to Stoneleigh - usually an assortment of all varieties on display.
                  Jim
                    I certainly plan on going to Stoneleigh, so look forward to having a good look and perhaps trying a few for size.
                    Cheers
                    Jeremy
                      If you come to the Club stand and make yourself known I am sure we can find some cars for you to try for size.
                        Hi Jeremy, Your more than welcome to sit in my roadster and try it for size.
                          Hi Jeremy,
                          Have you considered the Berlinetta? Plenty of leg room. There is one advertised on this site and is only about 60 miles away from you.
                          Huw
                            Thanks everyone for the offers, I am looking forward to having a good look at the cars at Stoneleigh.
                            Will be with Huw in his Berlinetta but its okay I have still not succumbed to indoctrination!
                            Cheers
                            Jeremy
