Last night the starter motor needed a persuasive tap with a hammer to convince it to work. Is this the point where I need a new one or will a bit of fettling fix it ? It's on a 1.7 Marina engine.
Starter motor
Re: Starter motor
Is it an inertia starter or pre-engaged?Often the terminals to the starter corrode,that's a quick and easy fix.If it's an inertia unit,and it spins but won't engage then cleaning and greasing the helical shaft may help.Mind you,if it's an old unit i'd be tempted to replace it,as it will finally give up on a dark wet windy night when you are miles from home!Thats the nature of cars...or is that just my cars??
Re: Starter motor
The inertia type were fairly common on the older "production" classic cars due to simplicity and cost. All the workshop manuals that I have read say not to use even thin oil on the bendix screw as it just causes dirt to build up (as per Don's comment above). I have always used an old toothbrush and a good degreaser to remove all traces of oil and dirt. I then sprayed the thread with GT85 or similar as used for bicycle chains. When it has evaporated it leaves a minute film of PTFE which is all the lube that the bendix thread requires. Peter.
Re: Starter motor
Although the starter motor seems to be working at the moment its probably time to replace it. Can anyone identify the model of starter motor this is ? Can't see any numbers so I might have to take it out and have a look. I've found a Lucas LRS293 that's for a 1.7 Ital but I don't want to buy the wrong one.
Re: Starter motor
Bought replacement off eBay, clown selling it suddenly realises its not what he thought it was. Bought brushes, opened starter - looks like a bag of sh*te inside ! Bought another starter off eBay for £50, now fitted and car starts first time. Anyone want an old starter and a set of brushes ?
Re: Starter motor
Do you have any identifying part numbers from the new starter?
Also part numbers for brushes etc.
Problem solved. Good.MOC member since 05/97
