Thread: AFM (Air flow meter) mounting BMW E30
Results 1 to 10 of 17
  1. #1 AFM (Air flow meter) mounting BMW E30
    56
    I would be interested to know how others have mounted their AFM. If you try to mount it in the (standard) position as dictated by the inlet to the throttle body it's clearly gonna be hanging out the engine bay!
    Also what is generally being used for the filter. The BMW one is huge and ain't gonna fit. What about one of the K&N induction kits?
    Robin
  2. #2 Re: AFM (Air flow meter) mounting BMW E30
    berkshire
    86
    Robin
    I had to overcome these problems with the BMW engine instalation in my cabrio. Take a good look at my artical's and photo's in pitstop.Briefly you have to rotate the airflow meter 90 degrees and make/buy an adaptor to fit a cone type filter. Alternately phone me 1 evening and I will try and help.
    Peter 01635 860587
  3. #3 Re: AFM (Air flow meter) mounting BMW E30
    139
    Thanks Peter
    I thought I might have to do that but I was concerned abiout the AFM working properly if I rotated it (gravity on the flap) I guess if it works in yiours it isn't a problem. I haven't got the pitstop in question so I will probably give you a ring some time in the next few weks when I return to that side of the engine (working on the exhaust at the moment)
    Robin
  4. #4 Re: AFM (Air flow meter) mounting BMW E30
    54
    Hi Peter,
    any chance of posting a picture or two here on this forum, as I'm sure there are a few of us interested to see your solution to this problem.
    many thanks
  5. #5 Re: AFM (Air flow meter) mounting BMW E30
    berkshire
    86
    Sorry chaps but have been unable to adjust my pictures to meet required size for forum. If you leave email address I will email pictures or pitstop artical to you direct.
    Peter
  6. #6 Re: AFM (Air flow meter) mounting BMW E30
    139
    If you email them to me patrick(at)msportster.co.uk I can host them for you
  7. #7 Re: AFM (Air flow meter) mounting BMW E30
    56
    Hi Peter
    While you are at it please could you email them to me as well
    martinclan(at)tiscali.co.uk
    Robin
  8. #8 Re: AFM (Air flow meter) mounting BMW E30
    2,034
    Message originally posted by: Patrick Short
    Hi Peter,
    I've stuck those two images up here:
    http://www.msportster.co.uk/data/P6300101.JPG
    http://www.msportster.co.uk/data/P6300105.JPG
    Thanks,
    Patrick
  9. #9 Re: AFM (Air flow meter) mounting BMW E30
    54
    thanks to both of you........
    Peter
  10. #10 Re: AFM (Air flow meter) mounting BMW E30
    berkshire
    86
    Hi guys
    More info for you. The filter I used is a jetex filter part number fr-06502 which was ordered from halfords at reading.
    Adaptors for conical filters are available from demontweaks and are known as "top hat" adaptors plus there is a specific bosch one listed in this years catalouge.
    Had another go at reducing pics today.
    Peter
  1. dash mounting
    By cameronfurnival in forum Roadster
    Last Post: 06-06-2011, 11:38 PM
  2. Diff Mounting
    By paul in forum Cabrio / Hunter
    Last Post: 20-01-2009, 05:02 PM
  3. B-Series oil flow problem
    Last Post: 04-02-2007, 02:21 PM
  4. Mounting the Airflow Meter (again....)
    By r.norman227 in forum Sportster
    Last Post: 18-11-2005, 08:31 AM
  5. e36 air flow meter
    By amalgamated users from prior forum in forum Sportster
    Last Post: 15-09-2005, 03:25 PM
