Results 1 to 10 of 13
Thread: Tyre Pressure's
  1. #1 Tyre Pressure's
    Jan 2012
    Emsworth. Hants
    17
    Hi,
    Has anyone any advice on tyre pressures?
    I have a Sportster with the BMW straight six engine with 195x50's on the front & 215x60's on the rear.
    At present I am running the fronts at 24psi & the rear at 26psi.
    Ian
  2. #2 Re: Tyre Pressure's
    Hi Ian i have been having a simlair debate with myself what to run my cabrio pressures at ????
  3. #3 Re: Tyre Pressure's
    club member Club Member
    Bakewell Derbyshire
    292
    Hi With 215/70 x 15 all round, I'm currently running with 22psi front and rear. Regards David
  4. #4 Re: Tyre Pressure's
    Jan 2012
    Emsworth. Hants
    17
    How is the vehicles road holding and feel with the pressure's set at 22psi?
    I am contemplating lowering the rears to 24psi and keep the fronts the same. I suppose its all down to trial and error until the vehicle's handling feel right???
    Ian
  5. #5 Re: Tyre Pressure's
    Bakewell Derbyshire
    292
    Hi Ian. Roadholding and ride feel o.k. to me. However when my present tyres wear out I'm tempted to change to 225/60 rear and 215/60 front to gain a little more feel (slightly lower sidewalls) as well as an aesthetic benefit( to my eyes anyway). As an aside, what is your ground clearance like with the tyres you have fitted, with my Rover engine I've got 41/2 inches under the nearside exhaust manifold. So changing tyres would reduce it , but only by approx 20mm. Regards David.
  6. #6 Re: Tyre Pressure's
    Jan 2012
    Emsworth. Hants
    17
    Hi David,
    On my Sportster the lowest point is from under the exhaust crossover pipe which is around 3", not a lot of clearance. I avoid speed humps at all cost!!!
    Regards Ian
  7. #7 Re: Tyre Pressure's
    Hereford
    94
    Hi Ian, on my sportster I have 195/65/15 all round, at 20psi. Marlins recommended 18 psi because my wing brackets kept breaking. Regards Rob
  8. #8 Re: Tyre Pressure's
    Jan 2012
    Emsworth. Hants
    17
    Hi Rob,
    Thanks for the reply. I think I will experiment with the pressures set between 20 psi on the front and 24psi on the rear. Interesting comment re: Marlins advice regarding the front stays. Are yours the original single fastening front and back or the later dual fastening points.
    Regards Ian
  9. #9 Re: Tyre Pressure's
    Miramar, Valencia, Spain
    35
    Having experimented with a variety of pressures I have found that 22 psi all around suits my Marlin Hunter V8 best – unbelievable road holding around the tightest of bends. Remember that fine tuning the shock absorbers is also VITAL!!
  10. #10 Re: Tyre Pressure's
    Hereford
    94
    HI Ian,
    I originally had the hollow tube stays fitted to the BMW upright with an exhaust clip, which sadly failed several times. Now I run solid bar stays with an exhaust clip bracket welded to the BMW upright - this has been successful for the past three years.
    Regards Rob
  1. Rad cap pressure
    By andyf in forum General Car Chat
    Last Post: 13-06-2016, 09:23 PM
  2. Cabrio tyre pressure
    By cmnc in forum Cabrio / Hunter
    Last Post: 23-07-2014, 03:15 PM
  3. Tyre pressure
    By Taylor in forum Cabrio / Hunter
    Last Post: 19-07-2014, 06:10 PM
  4. tyre pressure
    By fredsajs in forum Berlinetta
    Last Post: 24-05-2011, 02:37 AM
  5. Tyre Pressure Survey
    By greatoldone in forum Sportster
    Last Post: 18-03-2010, 11:40 AM
