Results 1 to 6 of 6
Thread: V8 Exhaust manifolds for the Marlin
  1. #1 V8 Exhaust manifolds for the Marlin
    frequent forum contributor HunterV8Spain's Avatar
    Miramar, Valencia, Spain
    35
    Does anyone know where these are available?
  2. #2 Re: V8 Exhaust manifolds for the Marlin
    frequent forum contributor CosworthCabrioLee's Avatar
    887
    Hi you will need to get itmade to fit the car as will need to be bent around the column etc . Not sure about Spain but peoLe like pd tough of Nottingham or power speed auto of Kent will do these but at a cost. You may struggle to get change out of 1000 for both headers and if you go the whole hog with the full system budget 2000
    I will try and find some pictures of some headers on a v8
    Marlin Cabrio Cosworth
  3. #3 Re: V8 Exhaust manifolds for the Marlin
    35
    Hi, thanks Lee, I do already have a set on my car which have had a minor repair. Thought about replacing them with new ones but a price of at least a Grand has changed my mind somehow..........
  4. #4 Re: V8 Exhaust manifolds for the Marlin
    887
    Some pictures of a V8 i used to own theexhaust was supplied by Marlin but in mild steel.
    What have you got on your car................
  5. #5 Re: V8 Exhaust manifolds for the Marlin
    35
    Quote Originally Posted by CosworthCabrioLee View Post
    Mine look to be the same as those, in mild steel also - the rest of the system is stainless.
  6. #6 Re: V8 Exhaust manifolds for the Marlin
    Exeter
    1,311
    These manifolds are on the 3.9i V8 on my Hunter. They are a 4 into 2 into 1 set up on both sides - unlike Lee's photo which appear to be 4 into 1. My 2 into 1 join is out of the photo under the floor area. Mine are stainless but the non-preferred brittle spec, hence the fracture I experienced some while ago, now repaired. Local firm Phoenix gave a ball park quote of around 1000 for new ones too! They also suggested having them ceramic coated for heat insulation rather than using heat wrap. Peter.
  1. Stainless Manifolds for Hunter / Rover V8 engine
    By greyV8pete in forum Cabrio / Hunter
    Last Post: 19-07-2018, 01:16 PM
  2. Re: Slow progress with the Marlin exhaust
    By terryreed1664 in forum What did you do with your Marlin today
    Last Post: 02-02-2013, 03:28 PM
  3. Slow progress with the Marlin exhaust
    By Harry in forum What did you do with your Marlin today
    Last Post: 01-02-2013, 07:46 PM
  4. Metro Inlet and exhaust manifolds - URGENT
    Last Post: 15-02-2009, 03:24 AM
  5. MARLIN STAINLESS STEEL EXHAUST
    By str11ker in forum Roadster
    Last Post: 02-06-2007, 12:22 PM
