Can I fit MGB wheels?
  • Can I fit MGB wheels?
    Hi
    My first post!
    I've got a 1990 Roadster running Marina parts, MGB engine and 13" wheels. I need new tyres and am considering larger wheels. I wonder if I can fit the 14" MGB wheels as replacements. A lot of MGB bits are the same as Marinas but I can't find any details about the wheels on the forum.
    thanks Dave
    Re: Can I fit MGB wheels?
    Hi Dave. I asked the same question of someone a few weeks ago but if I understand correctly you have to have the van rear axle and front hubs fitted , but dont quote me on that. I wanted to do the same as you on my 1986 roadster. Cheers Chris
      Hi Dave if you are running std marina hubs they 3.75" pcd MGB are 4" pcd not many wheels fit but MGf wheels go on with spacers and are cheap .
      Lee
        If you have Marina saloon axles then the 3.75" PCD is common with many Triumphs, Spitfire, Dolomite etc. The standard Marina offset is 1/2", spacers will need to be calculated depending on tyre width. The problem area is the front upright and the gap between it and the tyre itself.
          Hi
          If you require some spacers I have 2 going for nothing.
            Hi Adrian
            That would be great!
            I'm on holiday in a couple of weeks and High Wycombe isn't that far. The spacers would be for the front wheels, I presume.
            Nice looking Marlin. Mine is Ivory White.
            thanks
            Dave
