Hi it's been a while since my last post on engine changes and you have proberbly gussed from the title. I have gone for a black top zetec out of a focus donor car I have been busy beavering away when I can ,and have nearly got to the point where I can drop the engine into the car and have a look at its best position for it.my question is should the ruber engine mounts be set at a angle or is it ok for them to be upright so the metal mounts literally sit on top, hope this makes sense also which rubber mounts would you use? And are three mounting points one on the gearbox and two on the engine surfishent.
Thanks Angus
Thanks Angus
