Thread: Triumph Front Suspension, Anti Roll Bar
Results 1 to 3 of 3
  1. #1 Triumph Front Suspension, Anti Roll Bar
    Mar 2012
    South Lakes - UK
    586
    There are no ARB brackets on my hybrid chassis. My prime intended purpose for the Marlin is trials, so since I want to keep both rear wheels firmly on the ground as far as possible I feel a lack of ARB is acceptable because the front suspension will articulate more easily with no ARB.
    But, what about normal road use, Will it likely wallow, like a sow pig's belly, every time it sees a corner?
    If I am to have an ARB, then the time is fast approaching when I need to fit the brackets.
    So, ARB or not, what say you?
  2. #2 Re: Triumph Front Suspension, Anti Roll Bar
    SE London
    2,171
    The hybrid does away with the anti roll bar as it uses the live rear axle and the chassis/track is 2 inches wider than the donor Triumph so it wouldnt fit without modification.(thats why there is or should be an extension on the nearside track rod) I think you will find the front a bit stiff any way the softest regular Triumph spring would be for a Spitfire MK1 2 or 3.
  3. #3 Re: Triumph Front Suspension, Anti Roll Bar
    Mar 2012
    South Lakes - UK
    586
    Thanks Ben, I kinda touched on this in the other Triumph thread.
  1. Anti Roll Bar
    By ggrum in forum Cabrio / Hunter
    Last Post: 21-05-2018, 05:39 PM
  2. Anti roll bar
    By bladerunner996 in forum New members' forum
    Last Post: 04-05-2017, 05:03 PM
  3. Front Anti Roll Bar Diameter
    By greyV8pete in forum Cabrio / Hunter
    Last Post: 09-12-2011, 10:17 PM
  4. front anti roll bars
    By amalgamated users from prior forum in forum Berlinetta
    Last Post: 27-04-2006, 09:05 PM
  5. BMW Sportster - Front anti-roll bar
    By martinclan in forum Sportster
    Last Post: 03-07-2005, 11:09 PM
