wire wheels
  • wire wheels
    Is there an acceptable run out allowance on 13 inch wire wheels with knock ons ? Fitting to my mk2 Marina based Roadster. Cheers Chaps.
    Re: wire wheels
    Have a look at this site it may answer a few questions
      Re: wire wheels
      Thanks Ben, ideal. Going to have a go myself and see how I get on. Nothing venture ,nothing gained as the bad wheel is an odd one anyway but will do as a spare....Cheers Chris.
        Re: wire wheels
        I can remember doing my cycle wheels, just do it a little bit at a time. You really need a hub stand to set the wheel up on.
        Take some pics and let us know how you get on. Perhaps even a little article for Pit Stop,
        Best of luck Ben
          Re: wire wheels
          Hi
          Triumph recomended 0.05 inch wobble and lift for wire wheels. I was going to attached the relevant pages from the original workshop manual but the image is too large.
          Nick Tinsdeall
            Re: wire wheels
            From a Spitfire Manual.
            Wheel Run-out and Ovality
            The maximum tolerances for both run-out and ovality are as
            follows:
            Press steel wheels .. .. .. 0.070" (0.l8mm.)
            Wire spoke wheels .. .. .. 0.060" (0.l5 mm.)
              Re: wire wheels
              Thanks everybody. will let you know how I get on....Cheeers Chris
