Berlinetta build and restoration
  • Re: Berlinetta build and restoration
    I did think about a tie bar so after these comments I will fit one. The bracket is bolted through the original top mount and so is not totally reliant on the weld, which would definitely not be strong enough without the bolt.
      I made a couple of tie bars to provide extra support for the new seat belt mounts. I used 25 x 4mm flat bar and bolted it through the damper mounting post in the boot.
        Fuel filler cap. The original cap has seen better days.
        I never really liked this cap, the large rubber grommet looked rough and the latch was a bit hit or miss. So out with the old and in with the new.
        It required a larger hole, and also may need some filler as the panel is curved. It has a lock on the inside, my main worry not being theft but jokers dropping things in!
        A length of ultra flexible fuel filler hose connects it to the tank. The original tank had the filler on the side and had a right angle bend, which made it a pain to fill. The new tank has the filler on top. I may fit a partition in the boot to protect the hoses and battery from anything sliding about and hide them from view.
          really nice and neat...what is it called..I want one!
            I got it from CBS, just be sitting down when you see the price!
            I liked how it was a complete assembly, usually you buy the cap then find a neck followed by a lock. I also liked the slip ring to hold it in place rather than have to drill holes for small bolts or screws.
              Where does your fuel tank actually vent to?
                One of the small hoses next to the filler is the vent. The other is the return from the swirl pot. I plan to run the vent up to a point higher than the filler then down to below the boot floor, I may fit a roll over vent valve aswell.
                  Good idea. While we hope it won't be necessary it's always another thing not to worry about if it does go upside down.
                    My main worry is that sharp cornering may induce a syphon without the valve.
                      What tank? Are there any baffles in it?
                        The story of the fuel tank starts on page 10 of this build diary.
                          The bonnet hits the air intake. The truth is that I knew this was an issue from the start when I trial fitted the engine. I positioned the engine as low as allowed by the anti-roll bar,which runs under the sump. I am aware that there are several profiles of anti-roll bar so I made sure that I had the one that provided the most clearance. I considered removing the anti-roll bar but this did not appeal. I also positioned the engine and gearbox off center to help to give a little more clearance under the bonnet. I tried using rubber trunking to duct the air to the engine under the standard bonnet, but it was too restrictive. So the last resort was a bulge in the bonnet.
                          I'm not a bodywork person and so I have been avoiding this job for a while. I did some research online and bought some tools.
                          I started with some cardboard to work out the position of the bulge.
                          Then two plywood templates were made.
                          The bonnet was split into individual sections and the plywood was G clamped in position. Then using a Bossing mallet and some gentle heat from a hot air gun the bulge was formed.
                          It was smoothed out using bodywork hammers and dollies, and perhaps it is now time for a professional to finish the job.
                            Great job!
                              Thanks. It was easier than I expected, I think I will have another go tonight at getting it smoother.
                                If you rub some hard soap on the alloy then heat it till the soap turns black it will anneal the alloy and make it easier to work with, as all the time your hammering it will work harden it.
                                Looks good though.
