Thread: Berlinetta build and restoration
Page 31 of 31 FirstFirst ... 21 29 30 31
Results 301 to 309 of 309
  1. #301 Re: Berlinetta build and restoration
    Mar 2013
    Fife, Scotland
    547
    A member requested some measurements by private message, but I am unable to post pics there. So I am posting them here for now.
  2. #302 Re: Berlinetta build and restoration
    By Douarnenez Bay Finistere
    497
    Hi scott,
    twas I, I am asking for the depth from the underside of the dash top ie the apex of the inverted 'V' to the base of the main dash, ie is it 30cms or less, I'm considering a Europa blank! that is if as normal questions to French wood suppliers do not generate a responses. I don't know how they survive with their service levels!! I also realise it's the holiday silly season here!
  3. #303 Re: Berlinetta build and restoration
    Mar 2013
    Fife, Scotland
    547
    Quote Originally Posted by Tony Stott View Post
    Hi scott,
  4. #304 Re: Berlinetta build and restoration
    497
    eccellent, thanks for that!, the fog begins to clear! ;-))
  5. #305 Re: Berlinetta build and restoration
    Jan 2016
    Rugby
    249
    Hi scott,
    You think it's silly season now, wait until the first two weeks of August when the whole of Paris goes on holiday!
  6. #306 Re: Berlinetta build and restoration
    497
    They're already here by Dz Bay!! :-((
  7. #307 Re: Berlinetta build and restoration
    497
    Resurrecting this, page 20, the heater control, is it by Europa?, and the vent adjust, is that home made? if not for both, from where?
    thanks
    tony s
  8. #308 Re: Berlinetta build and restoration
    Mar 2013
    Fife, Scotland
    547
    thanks
    tony s
    Hi Tony, the temperature control was supplied by car builder solutions, as were most of the heating and ventilation components. The temp control is designed to fit through a thin metal panel, it has a slot on one end into which the panel would fit and is secured by a small screw on the other end. I had to carefully shape the dashboard blank with a dremmel until it was more or less only the veneer left to mount the control, so not ideal but it worked out ok.
    The lower vent control is home made. There are some pics in the build diary of the workings. It is a bent rod with a washer welded in the bend. This is bolted to a bracket mounted on the panel, with a small spring on the bolt so that it can be adjusted to provide the ideal amount of friction for the control. Mig welding wire was used to link the rod to the flap valves which were again sourced from CBS.
  9. #309 Re: Berlinetta build and restoration
    497
    thanks scott, completely missed that on the cbs site, age and failing eyesight I suspect. workshop here I come,later in the week it is then!
Similar Threads
  1. Berlinetta restoration
    By cameronfurnival in forum Build and Rebuild Diaries
    Last Post: 11-05-2018, 08:09 PM
  2. Restoration
    By tomallen_2003 in forum Roadster
    Last Post: 19-04-2008, 02:42 AM
  3. Belinetta Build Website (www.marlin-berlinetta.com)
    By amalgamated users from prior forum in forum Berlinetta
    Last Post: 16-03-2007, 02:42 PM
