Results 1 to 10 of 35
Thread: Overheating in a Marina Roadster
  1. #1 Overheating in a Marina Roadster
    3,319
    I was reading with interest the thread in the Sportster section.
    http://www.marlinownersclub.com/foru...p?4716-Louvres
    Marina Roadsters, particularly 1.8's historically have suffered from overheating issues, often discussed on this forum and in Pitstop.
    Even now there are Roadsters that have yet to have louvres in their engine compartment side panels.
    The same company that helped with a Sportster could also help with a Roadster.
    There are several other things that can be done to help a Roadster, all detailed on this forum, but I have tried to collate them all at http://www.keepandshare.com/doc/4039...34-pm-48k?da=y
  2. #2 Re: Overheating in a Marina Roadster
    Helston, Cornwall
    21
    As a follow-up to Steve's excellent summary of solutions to overheating problems, I can report that after some thorough investigative activities including ignition timing, carb settings and a rebuilt brake master cylinder (all of which were necessary) my 'overheating' has just been solved with a new temperature sender!
  3. #3 Re: Overheating in a Marina Roadster
    3,319
    Does that mean I have to amend my document? I know its not listed.
  4. #4 Re: Overheating in a Marina Roadster
    Moderator Club Member
    Derby
    1,465
    I had same problem with apparent overheating when I built my 1275 roadster. Turned out that the 'Marina' sender was incorrect match for the Smiths gauge I used at the time
  5. #5 Re: Overheating in a Marina Roadster
    frequent forum contributor neiltechspec's Avatar
    Sutton Coldfield
    103
    Put a proper temperature gauge in - a mechanical capillary.
    Mines a 1500 Triumph with a re-cored Toledo rad (1300) & 13" fan on the correct side (engine side) and no mechanical fan, it doesn't overheat.
    Neil.
    Ex owner of a Hybrid Roadster LWB.
    It's now in France somewhere.
  6. #6 Re: Overheating in a Marina Roadster
    Horsham
    217
    Hmmm.. I remember reading about the sensor problem years ago and was encouraged at the prospect of an easy fix. It wasn't. It's the bodywork; even after all my endeavours the car is still tempted to get hot when pushed - I'm considering vents in the bonnet to finally sort it out.
    1984 Marlin Roadster, 1.8 Zetec Black Top, Type 9 box, Griffin Power Systems Injection, Ashley Manifold + stainless exhaust, Omex ECU, Dunnell Alternator, Davies Craig Electric Water Pump & Digital Controller, Raceline Water Rail, K&N Air Filter. Dynod at 150BHP
  7. #7 Re: Overheating in a Marina Roadster
    Jun 2013
    Werrington, Stoke-on-Trent
    317
    One of the receipts that came with my 1800 powered Roadster is for a "special" radiator with larger core. I've not had the engine running so don't know if it made any difference by my car hasn't the louvres that others seem to need. Maybe all it takes is such a custom rad with 4 cores instead of normal 3 cores or whatever rad specialists do
    Paul H
  8. #8 Re: Overheating in a Marina Roadster
    Horsham
    217
    Quote Originally Posted by CompoSimmonite View Post
    Paul H
    I've got a receipt for several hundred quid for a custom aluminium radiator ;-) Didn't make a fat lot of difference to the re-cored Viva rad I had previously.
  9. #9 Re: Overheating in a Marina Roadster
    Suffolk
    447
    Several years ago I replaced the 1.3 'A' series in my Roadster with a 2 litre Alfa DOHC and was mindful of the risk of overheating so I did two things a) had the original Vauxhall (Viva or Chevette, I can't recall which) radiator re-cored and b) fitted a thermostatically controlled electric fan with manual override in front of the rad. I fitted a low temperature switch in the rad so that the fan would come on early rather than late. The engine bay has louvres down the sides only. The car has never overheated and the fan only comes on when stuck in traffic in really hot weather. There are maybe two reasons for this. The engine is virtually all alloy rather than cast iron so probably gets the heat away more efficiently and it has a large finned alloy sump that takes 6 litres of oil. With the 'B' series you can't do anything about the metal it's made of but maybe the addition of an oil cooler would help. Just a thought
  10. #10 Re: Overheating in a Marina Roadster
    Jun 2013
    317
    I wonder if an oil cooler would help ?
    The Sprite 1275 I'm fitting, in place of the 1800TC, has a cooler so intend keeping it.
    Paul h
  1. Regarding overheating
    By FranklinLeicester in forum Roadster
    Last Post: 08-08-2009, 02:26 AM
  2. Overheating
    By Joseph.Ryan1 in forum Roadster
    Last Post: 28-07-2009, 04:40 PM
  3. Roadster overheating again.
    By rob-53uk in forum Roadster
    Last Post: 15-09-2006, 08:41 PM
  4. Overheating?
    By robert in forum Roadster
    Last Post: 11-09-2006, 09:18 AM
  5. Overheating
    By b_l_macleod in forum Roadster
    Last Post: 27-08-2006, 12:34 PM
