Marina 1.8tc clutch lever position
  • #31
    Re: Marina 1.8tc clutch lever position
    It's surprising how much flex in the bulkhead there is, even with a servo.
    I fitted the factory modification albeit with servo in place it didn't go where Marlin intended it to.
    Like Sidon suggested I piggybacked the chassis rail & underneath the servo.
    Never did understand why Marlin recommended bracing it on the ally bonnet side when the chassis rail offered a much stronger locating point.
    • #32
      Just picked this picture from the FastMarina forum. It's a Marina clutch arm where the pivot pin has burst, or worn through the arm itself. Nobody has seen this failure mode before. Obviously the arm had to be replaced.
      Here or there
      • #33
        Interesting. I had problems with my clutch release arm last year when it slipped off the pivot pin and I was grateful for help from Steve and others in getting it back in the correct position. My retaining spring must be broken so when slave cylinder pressure is removed, the arm can slip off it's pivot. I thought at the time that the metal felt a little 'thin' at the pivot point.
        I plan to remove the engine from mine this Winter in order to change the camshaft (a previous owner was too ambitious with the cam that is fitted), clean up the engine bay and detail the engine, but I will change the clutch whilst it is out and have a closer look at the clutch arm. Another problem with mine is that I get a temporary grinding noise when the clutch is depressed when cold. I think it may be the spigot bearing spinning in the end of the crankshaft that tightens up once it gets a bit of heat into it. What do you think?
        • #34
          That arm is the same as Triumph Vitesse and GT6 and is known for cracking across the dimple, some repair by welding not sure of availability of replacemets. Further research look up Landrover V8 heavy duty arm(similar design)and it shows an extra plate welded over the dimple. http://www.ebay.co.uk/itm/RANGE-ROVE...YILWhllEWbR-Vg Needs a good dollop of copperslip or similar.
          Si your grinding noise is more likely to be the release bearing rumbling.
          • #35
            This is an old post I resurrected as it has photos etc. already there. When I try to cross reference the Marina, Vitesse and GT6 I get different part numbers, they may be similar but not quite the same.
            It's the failure mode that is odd. I have never seen it on a Marina before, so I thought it would be of interest over and above the cracking problem that has been mentioned before. Replacements are the proverbial rocking horse sh!t.
            Welding a cracked arm in unlikely to be as strong as the original due to fatigue, but plating over the dimple might save some work in the future.
            • #36
              Thanks Ben. I will know for sure once it is stripped. Will post results. I'm off work next week so plan to have a few runs out, then tackle the jobs over the following few weeks.
