Lifting vehicles
  • Lifting vehicles
    As I find I am falling to bits and suffer from a few problems with my back I was thinking about maybe making a ramp to lift the little marlin a bit higher off the ground. I have looked at all sorts of devices but wondered what other members use? Im thinking that something like the MR1 http://www.carlift-ramp-mr1.com/ sort of thing but engineered a bit better so it doesnt bend inthe middle might do the trick. thoughts?
    Re: Lifting vehicles
    There was a ramp, with a jack to lift it to the horizontal in a old Pitstop.
    Can you find it?
      Yes, that was the one that I made up. Still use it and as my drive is a 1:7 slope can run the car on to it without having to raise the end and work under it with plenty of room.
      Must have been back in 2007, 2008 when I did the mag. article.
        This is what I'm using, makes life a lot easier.....
        Available on eBay, around £1000-1200, fully hydraulic and 'mobile' all be it very heavy but it can be moved.
          Finally tracked it down to http://www.marlinownersclub.com/foru...5&d=1320759262
            Thanks for tracking that down. I have reproduced the article below. Love that scissor lift...wonder if 'er indoors would mind? hmmm.
              HI Cameron,
              I made my own lift a few years ago, which I consider to be safer than the one above, as the base of the red type jack pivots on a pin (it was originally designed for uneven ground) but I found on a slight slope it made the ramp unstable when lifted. I used two agricultural trailer jacks instead.
              Anyone is welcome to come and see my lift if they are considering this type of system.
              Rob
                Hi Rob,
                Can you post some photos of the lift?
                  Will try and sort some photos out over the next couple of days.
                  Rob
                    Here is a picture of one of the agricultural trailer jacks I used instead.
                    Rob
                      See the broom has broken down again Rob!
