List of Berlinetta Tech Articles in Pitstop
  • List of Berlinetta Tech Articles in Pitstop
    These are the articles up to Issue 181 Apr/May 2014 - and where to find them in Pitstop.
    Hope it helps
    Berlinetta Pitstop Articles – to 181 Apr/May 2014
    Berlinetta General
    A BREATH OF FRESH AIR Steve Aucock Aug 89
    BERLINETTA Steve Aucock Feb 90
    BERLINETTA TIPS Phil Steele Jun 90
    BERLINETTA OOMPH! Don Collins Apr 92
    MY CAR WILL NOT START David Kindred Dec 91
    BERLINETTA TOPICS Len Ball Aug 92
    BERLINETTA TIPS David Hobbs Jun 92
    BERLINETTA MODS A D JOHNSON Aug 93
    MORE BERLINETTA MODS! Colin Reeve Aug 93
    TECH TIPS from Phil Robertson, Berlinetta Tech. Adviser Mar 88
    MODIFICATIONS Len Ball Apr & Jun 89
    DEVELOPED THOUGHTS ON THE BERLINETTA Phil Roberts Dec 89
    Berlinetta - Seeking Advice Owen Hawkes Feb/Mar 01
    Reply from Paul French to Owen Hawkes Jun/Jul 01
    Tips cribbed from Wessex KCC Newsletter Apr/May 01
    Repair/Restoration Tony Johnson Jun/Jul 03
    Transforming a Berlinetta to LHD James Dresch JunJul 10
    Body Mods, Water Ingress, & Painting
    DOOR HINGES Jim Davis Sep 87
    RAIN CHANNELS Peter Hare Aug 91
    TROUBLE WITH BERLINETTA DOORS John G Wilson Oct 95
    BERLINETTA WINDOW CHANNELS (AGAIN) Mark Roberts Feb 96
    Berlinetta Technical Points Apr 96
    Berlinetta Wings Tony Johnson Oct/Nov 01
    Water Ingress David Ison Feb/Mar 03
    Re : Water Ingress Alan Hogg Aug/Sep 03
    Roll bar for Marlin Berlinetta James Dresch FebMar 10 Berlinetta Pedal Box Seals Jeremy Carrington Apr/May 2011
    Wind Deflector Bob Cawte
    Brakes, Clutch & Hydraulics
    (FORD) FRONT BRAKES Chris Wild Dec 91
    PEDAL BOX HAZARD (1) Mike Middleton Apr 93
    PEDAL BOX HAZARD (2) Tom Jones Dec 92
    “SPRINGY“ HANDBRAKE Mike Middleton Dec 92
    BERLINETTA PEDALS Chris Wild Apr 94
    BERLINETTA Handbrake Garry Christmas Oct/Nov 00
    Bleeding Brakes John Hammond Oct/Nov 01
    Electrical, Instruments and Interior
    BUILDING YOURSELF A “LIGHTS LEFT ON” WARNING DEVICE K L Martin Jan 89
    BAD STARTING/BALLAST RESISTOR Don Collins Apr 92
    SIDE REPEATER INDICATOR LAMPS Barry Greenhalgh Sep 88
    Berlinetta - Tonneau Cover, Rear Seat Belts Paul Snook Aug/Sep 00
    …………………..Response from Phil Hide Oct/Nov 00
    BERLINETTA Tonneau and rear seat belts Phil Robertson Dec 00/Jan 01
    Wiring Diagram for a Ford 2.0 DOHC Ian Hickson Jun/Jul 02
    Pinto Engine Management System Wiring Theo Thomas Oct/Nov 02
    Electronic Ignition System Stephen Middleton Aug/Sep 03
    Lamps and Clamps Keith Howell AprMay 08
    Nice dash for not a lot of dosh 1 Donnie MacDonald Dec08 Jan 09
    Nice dash for not a lot of dosh 2 Donnie MacDonald FebMar 09
    Nice dash for not a lot of dosh 3 Donnie MacDonald AprMay 09
    Fitting an Electronic Speedo Nick Teasdeall Jun/Jul 2012
    Drawing Instrument Dials on Your PC Keith Howell Oct/Nov 2012
    LED Lighting Dave Kitson Jun/Jul 2013
    Megajolt Fitment David Siddall Dec/Jan 2012
    Engines
    BERLINETTA ENGINE CHANGE Phil Robertson Nov 88
    Berlinetta – new engine Mark Roberts Jun/Jul 01
    High torque cam for Pinto ? Tony Johnson Oct/Nov 02
    …………………..…..Rely from John Hammond Dec 02/Jan 03
    Express Engine Transplant Terry Reed Dec/Jan 2011
    Hot Rod Berlinetta Roger Johnson Apr/May 2011
    Exhausts
    Exhaust System Walter Styles Apr 90
    EXHAUSTING BERLINETTAS Dave Ruslin Aug 89
    EXHAUST SYSTEMS Brian Gadd Feb 93
    BERLINETTA Exhaust Garry Christmas Oct/Nov 00
    Heating, Overheating & Cooling
    How cool are you? Peter Crowther Dec 09 Jan 10
    Heaters - Comment from John Hammond OctNov 07
    AntiFreeze in 2010 Part 1 Derek J Harris Dec/Jan 2011
    AntiFreeze in 2010 Part 2 Derek J Harris Feb/Mar 2011
    Hoods & Hardtops
    BERLINETTA HOOD CATCHES Dave Hunt Dec 93
    BERLINETTA HOOD IDEAS Alan Darbyshire Oct/Nov 98
    Berli Hood Fastening Roger Johnson Apr/May 02
    Hood to Cant Rail Fastenings Phil Robertson Jun/Jul 02
    HOOD CANT RAIL WATERPROOFING Aug 89
    Petrol Tanks, Carbs, Fuel
    BERLINETTA FUEL GUAGE CHRIS WILD Dec 93
    Cheap ‘n’ cheerful manual choke conversion Donald Macdonald Oct/Nov 06
    Petrol Tank Straps JunJul 09
    Rear Axle, Diff, Gearbox & Overdrive
    FITTING A SIERRA 5-SPEED BOX Brian Gadd Feb 93
    Rear Axle Bushes Ray Drinkwater Mar 87
    A few thoughts on Berlinetta axle ratios Phil Robertson Jun 95
    Berlinetta gear box Mark Barnes Jun/Jul 01
    Berlinetta Propshaft Problems? Mark Roberts Jun/Jul 02
    Seats
    BERLINETTA SEATS Malcolm Calder Apr/May 99
    Berli Question - Seats Roger Johnson Apr/May 02
    ………..Reply from From Peter Cork Jun/Jul 02
    Springs, Steering & Suspension
    SPRINGTIME Don Collins Apr 92
    SPRINGS AINT WOT THEY USED TO BE Dave Rusling Oct 92
    STIFF STEERING Dave Rusling Oct 92
    SPRINGTIME Geoff Beech Feb 92
    THE REAR SUSPENSION Brian Gadd Feb 93
    THOUGHTS ON BERLINETTA SUSPENSION SETTINGS Don Smith Apr 94
    BERLINETTA SUSPENSION...THOUGHTS THAT 'SPRING' TO MIND Bob Copping Jun 94
    BERLINETTA (CORTINA 4 FRONT SUSPENSION) STEERING RATTLES David Hobbs Jun 94
    BERLINETTA SUSPENSION Mar 95
    BERLINETTA STEERING VIBRATION - - - An Answer ? Tony Johnson Jun/Jul 98
    “THE CLONK” Alan Darbyshire Oct/Nov 98
    BERLINETTA - “THE CLONK” Dave Hunt Dec 98/Jan 99
    Berlinetta Front Suspension Trevor Benjamin Dec 98/Jan 99
    Berlinetta Comments from Phil Robertson Feb/Mar 99
    More on “The Clonk” Feb/Mar 99
    “LE CLONK” ! Malcolm Calder Apr/May 99
    TROUBLE WITH YOUR SUSPENDERS Andy Stephenson Jun/Jul 99
    Banging rear ends on Berlinettas John Hammond Jun/Jul 99
    Berlinetta Suspension & Steering Tony Johnson Jun/Jul 99
    Berlinetta V8 build - Part 2 - ‘Teething Problems’ Paul French Jun/Jul 00
    Springs, rearward-moved engines & how to make things more comfortable John Hammond Apr/May 01
    Berlinetta Springs Tony Johnson Jun/Jul 01
    Springs and Things John Hammond Aug/Sep 01
    Berlinetta Springs Tony Johnson Oct/Nov 01
    For Tony Johnson, ref Springs John Hammond Dec 01/Jan 02
    From Tony Johnson Jun/Jul 03
    Coil Over Shocks Berlinetta Martin Rodgers Oct/Nov 02
    A Longer Steering Column Paul Condliffe Apr/May 03
    Best Set up for Rear Springs Berlinetta Martin Rodgers Oct/Nov 02
    Wheels & Tyres
    TYRES Ron Jamieson Dec 91
    “WOBBLY WHEELS” (Comment on previous article) Steve Aucock Apr 90
    Berlinetta Tyres Tony Johnson Oct/Nov 01
    Tyre Sections, Tyres and Rim Sections John Hammond Dec 01/Jan 02
    From Tony Johnson Feb/Mar02
    Wheel & Tyre Sizes “Biro” Feb/Mar02
    Wheels Tyres etc Peter Daveny Apr/May 02
    Alloy Wheel Cleaner Biro Apr/May 04
    Workshop Tips etc
    SAFETY TIP (2) Mike Bagnall Feb 93
    Bowden Cables Peter Morris Oct/Nov 06
    Solderless Nipples without playing with fire! David Prowse Dec 06/Jan 07
    Car Ramp Hugh Cumming OctNov 07
    Berlinetta Builds & Rebuilds
    BERLINETTA BUILD Trevor Benjamin Aug 92
    BERLINETTA BUILD UP Phil Robertson Nov 86 & Jan 87
    Five Wheels on my Wagon Mark Roberts Oct 93
    BERLINETTA 1661 PART ONE J G Wilson Nov 94
    HAVE YOU GOT A RECEIPT FOR THOSE WHEELS? (Abridged) Jon Orme Dec 95
    BERLINETTA MODS Steve Large Jun 96
    Response from Bob Copping Jun 96
    BERLINETTA V8 BUILD - Q813 DPG (Abridged) Paul French Feb 97
    BERLINETTA MODS Tony Johnson Jun/Jul 98
    Dane's Moll Dane Crosby Dec 03/Jan 04
    Moll Part 1 –where the Berli story really starts Dane Crosby AugSep 07
    Moll’s Saga (No 2 of hundreds) Dane Crosby Dec08 Jan 09
    Moll’s Saga (The last part? I doubt it!) Dane Crosby FebMar 09
    My Berlinetta History 1986 – 2007 Jeremy Carrington OctNov 07
    A Marlin Story begins…….. Michael Davidson Dec09 Jan 10
    A Marlin story continues…….. Michael Davidson AprMay 10
    The Life and Times of a Marlin Owner 1 Dave Hunt FebMar 10
    The Life and Times of a Marlin Owner 2 Dave Hunt AprMay 10
    The Life and Times of a Marlin Owner 3 Dave Hunt AugSep 10
    Life & Times of a Marlin Owner 4 Dave Hunt Dec/Jan 2014
    Berli Build UK & Australia 1989-2014 M Brooks/ J McLaughlin Feb/Mar 2014
    Berli Respray and Refit Gary Woolridge Dec/Jan 2014
    Re: List of Berlinetta Tech Articles in Pitstop
    That must have taken you a while Dave but a really useful list for Berli owners. Any chance of a similar one for the Cabrio? Peter.
      It's a rehash of the index for the Tech Tips I did back in 2010...the Cabrio one is now in the Cabrio section.....and I'm working on the somewhat larger Roadster list
        Berli brilliant!!!.
        Thanks Dave this will save me a lot of time trolling though back issues, for info.
        Alan
          Just a thought, why not put this in the useful docs area
            Hello Dave,
            Thanks for Berli list- as restoring No 1 Sierra Berli also a new member is it possible to find these articles on Club website ? Thanks Paul W
              Yes Paul. They are articles in Pitstop magazine, you just look at the one you want to in the Pitstop thread
                Originally posted by PaulW View Post
                Hello Dave,
                Hi Paul. Im very interested to hear that you are restoring a Sierra Berlinetta as that is exactly what I am doing. It would be great to see some pics or even better a build diary. You can see what I have been up to in my build diary. You and I are a select few given that only 17 Sierra Berlis were made.
                  Check post 1, listing now correct up to Issue 181 Apr/May 2014
                    Hi Scott How is the Berli rebuild coming along or is it finished ? I am weighing up relining the hardtop any suggestions ?
                      Hi Paul, my rebuild seems to be never ending! I keep finding other things to do, but the end really is in sight now. I hope to take it to the painter in a week or two. After paint I am getting the interior done by a local specialist including the headlining that you speak of. I'm not sure where you are based but this trimmer is in Fife if that is any good to you? Do you know of a company called Woollies? They concentrate on trimming materials for cars and will probably sell the materials you would need to tackle it yourself.
                        "my rebuild seems to be never ending! I keep finding other things to do, but the end really is in sight now."
                        I know exactly what you mean! ??????
