Thread: 5 speed gearbox
Results 1 to 6 of 6
  1. #1 5 speed gearbox
    104
    hi all
    I have fitted the type 9 box to my 1600 crossflow. Yet to get the propshaft shortened hope to have that done next week. i have one problem has anyone got a spare gearstick from a capri or simular that will fit the type 9 box? if so willing to pay a reasonable price
    cheers
    bob
  2. #2 Re: 5 speed gearbox
    2,034
    Message originally posted by: matthew Sykes
    Bob , what was involved in the conversion then?
  3. #3 Re: 5 speed gearbox
    104
    hi Matthew
    Briefly,up to the stage i am now the clutch had to be changed to a sierra 23 spline clutch as the input shaft is bigger, the shield between the engine and bell housing had to be altered to fit the starter motor,the original clutch release arm fouled a bolt holding the gearbox to the bellhousing so a slight adjustment with a grinder did the trick,the reverse light switch fouled the transmission tunnel so a hole was drilled to accomadate it, the gearbox mounting from the old box fits but needs resighting further back. i have yet to fit a speedo cable i believe one from a MKIV or MKV cortina will do the trick also i need to get the prop shortened bit concerned that it might be a bit tight in the tunnel.i have run the engine and selected all gears.hopeing some one will have a spare gearstick or will have to make one !
  4. #4 Re: 5 speed gearbox
    Moderator Club Member
    Derby
    1,376
    Bob,
    I can probably get hold of a gearshift from a Sierra that has a type 9 box,it just means a trip to local scrappies if that helps
  5. #5 Re: 5 speed gearbox
    Derby
    1,376
    Bob,
    Have obtained gearshift for type 9 box,if you let me know your address will post it on or whatever suits.No cost other than postage!
  6. #6 Re: 5 speed gearbox
    104
    Hi alan
    thanks mate you are a real gent. my e mail address is rob-53uk(at)talktalk.net if you could e mail me i will send my address
    thanks again
    bob
  1. ford 4 speed gearbox
    By rob-53uk in forum Roadster
    Last Post: 02-04-2006, 09:01 PM
  2. 5 speed gearbox
    Last Post: 24-02-2006, 07:39 PM
  3. 5 speed gearbox
    Last Post: 13-02-2006, 08:53 PM
  4. 5 speed gearbox
    Last Post: 09-01-2006, 08:12 PM
  5. Triumph 5 speed gearbox
    Last Post: 29-10-2004, 07:21 AM
