Thread: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roadster.
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
  1. #1 Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roadster.
    frequent forum contributor DamnedFrog's Avatar
    Oct 2014
    France, Limousin
    59
    Hello all
    Falling from Charybde to Scylla when I tried to fix things on the Roadster I bought from a german guy last november, all turned to be clear: It would be a complete rebuild.
    The car received its V5 in 1984 but prior that experienced a complicated birth: hole drilled and closed with mastic or left open everywhere, screws and nuts of very different quality from new stainless metric to used imperial, electric harness taken roughtly from the donor car and stretched to the limit...
    Yes Cameron, you were right, nothing but a complete rebuild was mandatory
    I was advised to open a diary, so here it is.
    Now the beauty is totally nacked, the serious game will begin with de-rusting and repainting.
    On the kitchen table Santa returned in April and all the necessary stuff for a brand new electric harness was received from English suppliers.
    Stay tuned
  2. #2 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Club Member dcunn's Avatar
    1,445
    OK looks like fun...what sort of time scale have you set to finish it ?
    Should we put this thread in with the build diaries ?
  3. #3 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Oct 2014
    France, Limousin
    59
    Yes indeed you can!
    Time scale... I would like that everything should be done this year.
    CAD work and chassis refurbishing should be carried out this month and during my holidays in may, let say that october is a fair target for first road tests.
    Christophe.
  4. #4 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Oct 2014
    France, Limousin
    59
    Dashboard temporary CAD drawing, before laser cutting of alu sheet.
    The dashboard features two 3mm sheets: a frontal one to hold the gauges, warnings and switchs, and a structural one behind so that stiffness of the assembly is sufficent for 4 point holding (2 lateral and 2 top) and for withstanding weight and vibrations. I did that because Lucas switches can not stand more than 3mm of panel thickness. A single piece made of 5mm would have been much less expensive.
    All smiths electronic classic gauges:
    - Tacho 80mm on the right, Speedo 80mm on the left
    - Right side: water temperature and fuel level
    - Left side: voltage and engine head temperature
    Santa made faces at me, but this would be AGAIN Xmas in may
    Christophe.
  5. #5 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    llandrinio Powys
    1,785
    I cant wait to see how that turns out
  6. #6 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Club Member David's Avatar
    High Wycombe
    1,126
    Make sure you have room to hold the gearstick in first and third gear without bashing your hand on the lower centre of the dash.
  7. #7 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Oct 2014
    France, Limousin
    59
    Hello David.
    I indeed took this in account, and therefore I reproduced the overall dimensions of the existing MDF dashboard, leaving enough room under for gearstick operation.
    And I'll use a thin rubber edge trim around the frontal sheet to prevent accidents
    Christophe.
  8. #8 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Oct 2014
    France, Limousin
    59
    Hello Cameron.
    I'll do my best to maintain this diary as pleaseant to read as I can
    To do: learn to use... a digital camera.
    Christophe.
  9. #9 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    frequent forum contributor Club Member Mike's Avatar
    Gosberton, South Lincs
    1,383
    If you can prepare CAD drawings like that, then Digital photos will not be a problem !
    Looks very impressive.
    Quote Originally Posted by DamnedFrog View Post
    Hello Cameron.
    Christophe.
  10. #10 Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    Oct 2014
    France, Limousin
    59
    Good work today !
    - All paints (chassis/engine-gbox/manifold/radiator), primers, rust removers, cleaners and alu varnish ordered from RESTOM, a specialized French manufacturer with a very good reputation for classic car chemicals.
    - CAD design of dashboard is completed and transmitted for quotation of laser cutting (green:face/yellow:structure/magenta:dashboard and electricals holders)
    Stay tuned
  1. Roadster Rebuild Diary from Cornwall
    By meverett in forum Build and Rebuild Diaries
    Last Post: 16-06-2019, 07:46 PM
  2. Replies: 0
  3. Operation Tank Replacement
    By andyf in forum Build and Rebuild Diaries
    Last Post: 21-12-2015, 08:59 AM
  5. The Start: Operation Phoenix - Marina Based MKII.
    By Waterscumbie in forum Roadster
    Last Post: 18-03-2015, 03:26 PM
