Marina 1.3 exhaust downpipe
  • Marina 1.3 exhaust downpipe
    Hi
    Can anyone take a picture of their exhaust downpipe coming from the manifold and exiting the engine bay side.
    I know I have asked this before and it will be a little bit of an issue trying to get in there to take a picture but I would be forever thankful.
    Many thanks.
    Re: Marina 1.3 exhaust downpipe
    Hi Adrian,
    Just read your request. I'll send you a pic tomorrow. Mine has the standard Marina cast manifold with a tailor-made stainless downpipe exiting through the inner wing just above the chassis. I think this is the original way they were done..
    Franklin.
    Franklin, Leicester
      Many thanks Franklin
        Hi Adrian, mine is as near to original. I cut the downpipe about 2 ins from the flange then fitted stainless flexible which as Franklin says passes through the bonnet side panel just above the chassis rail. This then fits to an original stainless box, I twisted the flex until it tightened on to the downpipe section the clamped with a stainless u clamp. Works fine.
          Hiya
          Can you do me a picture if its not to much trouble.
          Happy to be PM'd
            Here are my pics. As you say, not easy to photograph but hope it helps. I'll be at Stoneleigh on Sunday. If you're there find Q880YAW and I'll not be far away. Franklin.
            Franklin, Leicester
              Here is no 3 for what it's worth. Franklin.
              Franklin, Leicester
                Thanks Franklin
                That does help.
                See you at Stoneleigh
                  I have one of these which I will have in my boot to give to DC - if you want a look at it before I hand it over
                    Is it a Stainless Steel one?
                      Yep It would be good to check it out.
                        Hi Adrian
                        Just been in the garage and taken a few pictures that may be of assistance.
                        The system is the original Stainless one supplied by Marlin.
                        Fingers crossed the pictures appear, don't post very often
                          Success!!!
                          If you need any more pics let me know
                          John
                            Hi John
                            That's great.
                            Was the downpipe supplied by Marlin?
                            I have exactly the same Stainless silencer.
                            Are you restoring yours as well?
                            Looks as though you are about the same stage as me.
                            Regards Adrian
                              John do you really have a chequer plated garage floor? that is so cool.
                              Mark.
