Chromed 'acorn' wheel nuts for a Roadster
  • #16
    Re: Chromed 'acorn' wheel nuts for a Roadster
    Originally posted by greyV8pete View Post
    Just a few random thoughts. I am a bit concerned to see 60deg taper. If those are alloy wheels I would expect to see 90deg seats? Also the thickness of the area being bolted looks a bit thin. Also some alloys (BMW?) have sleeved nuts with a flat location. Those counterbores look as though they are designed for that type of nut? Peter.
    The existing nuts are seating onto a steel insert with the 60deg taper. Given they've been there since 1987 I think we can say they work!
    I agree the amount of wheel material looks minimal, but I have a receipt from the wheel vendor (1987 again!) and they have supplied based on this fitment so again as above, 30 years of use must speak for itself.
    I agree re: the counterbores and that is what MisterTee is recommending, shanked nuts to slide into the hole with a bevelled washer to give the nut a flat seat. Th issue with this fitment is that I will probably have to shorten the nuts to avoid them tightening onto the hub before they grip the wheel itself.
    I've seen these wheels on a few Marlins so would be very reassuring to see/hear what those owners have done.
    • #17
      Hi David
      Not meaning to highjack this thread but I have the Marlin supplied Cosmics on all Marina running gear, what do the members think I should go with?
      • #18
        Found these on ebay...
        Stainless Steel or Chromed Mild Steel
        • #19
          Well mine have been on since '89 and the pics show the nut is a sleeved one with tapered washer. I don't have a inset in the wheel holes and the nut is nominally 5/8" dia. and 1/2" long.
          with the holes in the wheels being just over 5/8" Your studs don't seem as long as mine are they standard?
          How thick is your wheel flange, it must be more than 1/2"?
          I'm pushing out almost 150 brake and have had no problems.
          • #20
            Thanks for that h.m.cumming1, very reassuring...
            • #21
              Thanks Andy, those chromed nuts weren't listed earlier. May just go for those although I do like the idea of the flat fitting with taper washer shown here by h.m.cumming1.
              • #22
                Please call me Hugh
                • #23
                  Originally posted by h.m.cumming1 View Post
                  Please call me Hugh
                  Sorry Hugh, I didn't know who you were!
