Page 4 of 14 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 138
Thread: Marina Roadster 1.8TC Q67 GJA
  1. #31 Re: Marina Roadster 1.8TC Q67 GJA
    SE London
    2,206
    You look fully trolleyed, ventured into workshop to look at things and lasted about an hour.
  2. #32 Re: Marina Roadster 1.8TC Q67 GJA
    High Wycombe
    1,157
    I managed to loosen the bottom hose on the radiator enough to drain a few litres and top up with fresh anti-freeze, run till hot, by then had enough, too cold. Will have to go back later to check levels and top hop though.
  3. #33 Re: Marina Roadster 1.8TC Q67 GJA
    Bakewell Derbyshire
    285
    Good to see that you take the gnome out of the garden over winter. David
  4. #34 Re: Marina Roadster 1.8TC Q67 GJA
    Suffolk
    446
    Only needs a fishing rod in his hand - he's already got the silly grin!!
  5. #35 Re: Marina Roadster 1.8TC Q67 GJA
    Club Member dcunn's Avatar
    1,548
    Visible progress, I've put new shells in the big ends and mains, pistons are all OK. Need to work on an idea for the bulkhead stiffener, maybe from the A pillar to the bulkhead ?
    Then give the engine a bit of head and add the other ancilliaries
  6. #36 Re: Marina Roadster 1.8TC Q67 GJA
    High Wycombe, Buckinghamshire
    1,941
    And you said mine was a neat job, yours looks wonderful. Keep up the good work.
  7. #37 Re: Marina Roadster 1.8TC Q67 GJA
    1,548
    Always looks better in the pictures rather than reality, but thanks anyway Adrian.
    One month on, slow progress, but it certainly won't make Stoneleigh this year !
  8. #38 Re: Marina Roadster 1.8TC Q67 GJA
    Gwynedd North Wales
    408
    Hey DC looking at the rear end pics - why are the shocks upside down ???
  9. #39 Re: Marina Roadster 1.8TC Q67 GJA
    1,548
    ..........................cos that's the way they were Lol
    Seriously (see post #25 pic)there's an eyed bushed end, and t'other end has a single threaded rod with two rubber donuts , nuts and locknuts which attaches to the spring plate.....it's the only way they fit !
    However, another thing I've noticed today - I put the prop shaft back in as it came out with the sliding bit to the front - the build manual says it should be at the back.
    Dunno why, but I guess someone will know better than me.
  10. #40 Re: Marina Roadster 1.8TC Q67 GJA
    Telford, Shropshire
    656
    Methinks someone ordered new dampers & didn't spec which end out of stem & eye should be which.
  1. Overheating in a Marina Roadster
    By stevejgreen in forum Roadster
    Last Post: 13-08-2020, 03:35 PM
  2. Marina LWB Roadster 1.8
    By lizbillings in forum SALES:
    Last Post: 23-10-2018, 06:15 PM
  3. Marina roadster on E bay
    By dbazdavies in forum Roadster
    Last Post: 20-11-2015, 08:31 PM
  4. Marina Roadster
    By cameronfurnival in forum Build and Rebuild Diaries
    Last Post: 15-04-2015, 04:45 PM
  5. marina based roadster
    Last Post: 20-06-2007, 07:25 AM
