1973 Marina Based Roadster Freshen Up
  • 1973 Marina Based Roadster Freshen Up
    Hi
    About time I did an update with my recently bought Roadster which has started to recieve its health check and freshen up ready for an MOT
    What had started out as some minor servicing and health checks quickly escalated.
    First surprise find was the wire spoke wheel adapters were not right for the car and they were botched up, resulted in the stud holes being elongated and wheels not mounted true to the hubs.
    To fix it we had some alignment adaptors machined up and drilled new mounting holes 90Deg out to the originals.
    After that we stripped all the brakes, cleaned and rebuilt with new seals
    New hard brake lines
    New Steering Rack Gator
    Pair of new spax shocks on the back
    Trunion bushes and rubbers to be replaced also
    The we got the next surprise, previous owner told me the head had already been converted for un-leaded, digging through the paperwork revealed yes the head had been rebuilt but as a standard head. We took the head off and found standard valve seats.
    Bit of machining later and valves were lapped into their new hardened seats and head back on. While we had it in bits we swapped out water pump and thermostat for peace of mind.
    Next jobs are install electronic ignition, get the engine running, balance and tune the carbs. Fit new front indicators, wire up front spot lights properly, tidy up some of the engine bay wiring that has Scotch Locks and badly made crimps everywhere, windscreen washer pump replaced, engine, gearbox and diff oil replaced, reweld some bad workmanship on the exhaust along with a newly fabricated mount and off for a MOT.
    Re: 1973 Marina Based Roadster Freshen Up
    Originally posted by hkp57 View Post
    Hi
    [ATTACH=CONFIG]6760[/ATTACH]
    [ATTACH=CONFIG]6761[/ATTACH]
    [ATTACH=CONFIG]6762[/ATTACH]
    [ATTACH=CONFIG]6763[/ATTACH]
    [ATTACH=CONFIG]6764[/ATTACH]
    Too late for the head, I would have had it ported, but not that important if you are not looking for more power.
    You don't mention the various bushes, especially the tie bar. If they are allowed to wear, both the bar a d the hole in the chassis can go oval. Easily cured but they make a big difference to handling.
    The rear shocks make a big difference as you are sitting in the axle, but I found it useful to go for Spax adjustables on the front as well.
    any electronic ignition will smooth out starting and power through the range. If you plan more power, Megajolt can be a way forward as it's almost infinitely adjustable.
    Looking good though.
      Hi Steve
      Thanks for the feedback, the goal for now is to get her on the road and get some miles under our belt. We already have a seven type kit car for speed so this is more of a Sunday Cruiser.
      Sometime in the future I plan a power train upgrade to enhance the lazy cruiser and toying with the idea of even a modern small turbo diesel. Not seen any diesels as yet.
      Need to do a bit more reseach on gearing etc before we plan that one. Just want to get away from Pintos, Zetec's and type 9 gearboxes. See whats out there in Autobox land that would match up.
        How about a Mercedes SLK as a donor. Various sizes but a 1.8 Kompressor might well fit. But not without major surgery.
        The downside would be engine control and the Merc auto box.
          Quick update
          With the head back on there were a few little jobs to do, first was to swap out the rusted out front indicators, which leaves a hole and some of the original red paint on show.
          Considering its going to my mates body shop next that's no issue.
          Next up was to change out the old steering wheel for a new one.
          Final jobs before the MOT was the electronic distributer and balance the carbs. While under the bonnet it was noted the fan was controlled by a switch on the dash so that was also wipped out and replaced by a thormostatic fan controller.
            MOT Passed today
              MOT Passed today
              Well done!
                Looking good!
                  Off to my mates Body shop now to get some TLC, there are some holes in the body where stuff was removed, some areas not that well finished in the paint so Davie will give it the once over before I give it to the wife .
                    Hi hkp57,
                    Lovely looking Roadster and lovely wheels. I am in the process of fitting wire wheels to my Roadster and I was wondering if you could tell me the size of your wheels and also the size of the tyres. I have gone for MGB 14" wheels with 175/65 tyres but I am having problems with the Offset. With this set up the tyres protrude outside of the running boards. Motor Wheel Services provided the centre splined hubs which are designed to fit a Kit Car but when fitted to the Marina front end the spacing is all wrong and there is too much stress being placed on the bearings.
                    Any info would be much appreciated.
                    Regards,
                    Chris
                      Hi Chris. Bogue, I have had wires on my roadster 13 inch Triumph Spitfire and bolt on hub splines. No problems encountered at all. Have to be honest I took them off after a few months I just did'nt like the look. Cheers Chris Holmes.
                        Chris Bouge
                        Unfortunatley I am back at work for a month so cant measure the offset, what I can tell you is they are 14" MGB wheels originally supplied by Rimmer Brothers, the only real issue we had was the ID of the bolt on adapters did not match the center of the hub so the bolts which had slightly over sized holes were doing all the work of transmitting drive and trying to center the wheels to the hubs, we took a light skim off the adapter to clean the back plate up then machined rings to go inside and align the adapters to the hubs.
                        After that we re-drilled new holes of the right diameter/
                          That's a very good point, Marina wheels are hub-centric. Many spacers and adapters are not, either for space or design issues.
                          The Marina particularly has wheel studs 4 x 3/8". Many modern cars are designed with 5 x 12mm studs, substantially stronger and more capable to transfer the torque, if they are designed to.
                            The Painter has finished touching up the paint where it was a bit rough and the red was showing through in a few spots.
                            Its waxed up and ready to give to the Wife, she knows nothing about it yet so lets see how this goes.
                            Pictures dont do it justice though. Need to get it out in the sun after the snow has stopped for a photo shoot.
                              Excellent looking car.
