Results 1 to 10 of 19
Thread: Mark 1 Roadster, can you identify this fuel tank?
  1. #1 Mark 1 Roadster, can you identify this fuel tank?
    Feb 2012
    Stroud
    45
    Hi
    My fuel tank is leaking so I have removed it from the car. Wanted ideally to get a replacement. Can someone firstly tell me what the tank originally came from. I have looked at pictures of escort tanks as people say this was what most people put in their cars originally. My tank doesn't seem to match pictures on-line though. Can anyone recommend someone who could fabricate a tank for me. I did some measurements so included these if they help.
    Dan
  2. #2 Re: Mark 1 Roadster, can you identify this fuel tank?
    llandrinio Powys
    1,785
    the original tanks were from a mk1/2 escort van and yours isnt one of them! Yours is a spridget tank!
    Click here...
    However getting a new bespoke one fabricated is straightforward, many members have done so and you will probably be contacted by some happy to recommend fabricators and give you a ball park figure of cost.
    If you look at DCs thread on here you will see his project was an early triumph car and that had a Hillman Imp tank.
  3. #3 Re: Mark 1 Roadster, can you identify this fuel tank?
    Feb 2012
    Stroud
    45
    Thanks Cameron. I will order one of these.
    Dan Cook
  4. #4 Re: Mark 1 Roadster, can you identify this fuel tank?
    llandrinio Powys
    1,785
    No problem, I would be interested to see how this tank fits as other members have asked about the spridget tank in the past and it may be a good solution as escort tanks are almost unobtainable. Any photos of the install would be great.
    PS please do check with suppliers concerning dimensions etc before ordering.
  5. #5 Re: Mark 1 Roadster, can you identify this fuel tank?
    Mar 2013
    Fife, Scotland
    587
    Quote Originally Posted by Marlindan1965 View Post
    Hi
    Dan
    Hi Dan, I started a thread on fuel tanks a few months ago. It can be found on this forum in "general car chat" page 3. It should give you a few pointers and perhaps you could add your experience when you get sorted out.
    Scott.
  6. #6 Re: Mark 1 Roadster, can you identify this fuel tank?
    Jan 2015
    51
    Nice, mine was a hillman imp tank when stripped down 15 years ago , I think I will go sprite , looking around the web you can get some good foam filled rally type tanks , anybody experienced on , they are about 200 though :-/ !!
    Scott.
  7. #7 Re: Mark 1 Roadster, can you identify this fuel tank?
    SE London
    2,211
    The Hillman Imp tank was originally recommended for the Mk1 we used a Reliant Robin tank in my sons Mk1
    a bit on the small side but it does ok,
  8. #8 Re: Mark 1 Roadster, can you identify this fuel tank?
    3,347
    Do Triumph based roadsters suffer from the same inaccurate petrol gauge reading, the same as Marina based cars do?
    if so its worth changing the sender to a compatible one if you go for a custom tank.
    There was an article on fuel tanks for a roadster in Pitstop, not sure which issue, DC's index might find it.
  9. #9 Re: Mark 1 Roadster, can you identify this fuel tank?
    SE London
    2,211
    It seems its the Ford tank not being compatible with Smiths gauges that causes the problem. Triumph, BL, Rootes and even Reliant all used the Lucas system with the 10v stabilizer .
  10. #10 Re: Mark 1 Roadster, can you identify this fuel tank?
    High Wycombe
    1,193
    Just saw this in my Twitter time line.
    Neil McKenzie @ArtMetal_Jersey
    Fairly recently, we fabricated a scratch-build #AstonMartin DB4GT Zagato fuel tank from original factory drawings.
    https://twitter.com/artmetal_jersey/...52494869209089
    David.
  1. Replies: 12
    Last Post: 16-10-2016, 08:19 PM
  2. Roadster fuel tank
    By b_caswell in forum Roadster
    Last Post: 11-10-2014, 10:33 PM
  3. YKC sierra roadster fuel tank & sender seal
    By PatrickBaggaley in forum Roadster
    Last Post: 10-07-2013, 04:30 PM
  4. roadster fuel tank
    By roblake91123 in forum Roadster
    Last Post: 21-01-2010, 03:04 PM
  5. What is the fuel tank capacity of a roadster tank?
    Last Post: 06-05-2006, 10:13 PM
