Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Tyres for a Marlin Roadster
  1. #1 Tyres for a Marlin Roadster
    Hi
    I am new to the website so hope I have done it right.
    I bought a Marlin Roadster back in April, but it was in the process of one engine half out and a new one about to go in, so it was picked up by a flatbed loader and the rest of bits and pieces went in boxes. I took possession of it last week so I'm like an excited child with a new toy.
    It now has a 1.6 fuel injection engine so is pretty quick. The mechanic who did it for me said the tyres were old, but not worn and very hard, making it ‘skittish’ on the road! He suggested I buy the cheapest tyres I could find as they would be soft and make it a bit more likely to stick to the road. I have no idea about these things so am hoping that one of you out there can advise me.
    The size of tyre on now is 185/70/13T ……… whatever that means.
    My local tyre place has suggested one of the following –
    Uniroyal - £58
    Conti - £76
    Firestone- £53
    Prices are per tyre and include fitting and VAT
    Please get back to me with your ideas, either on here or email fo.millais@hotmail.co.uk
    Fiona Millais
  2. #2 Re: Tyres for a Marlin Roadster
    Chester
    413
    Hi Fiona.
    Probably more important than the type of tyre is their pressure.
    I run my Roadster on 18psi and the handling is so much better. Anything above that the back end bounces about too much.
    There's plenty of advice to be found on Roadsters on this forum to help you.
    All the best
    Gareth.
  3. #3 Re: Tyres for a Marlin Roadster
    Mar 2013
    Fife, Scotland
    606
    A couple of years ago the rules on tyre labeling was changed. Each tyre now has the same label with a score for road noise, fuel economy and wet weather grip. This makes it much easier to compare different makes.
  4. #4 Re: Tyres for a Marlin Roadster
    Nov 2015
    49
    The best choice is Continental.
    Uniroyal and Firestone are almost the same.
    You can try the Falken Sincera (good japanese tyres - the porsche choice) probably the cheapest ones with high quality.
  5. #5 Re: Tyres for a Marlin Roadster
    High Wycombe, Buckinghamshire
    2,010
    I had Falkens on mine and they worked well.
  6. #6 Re: Tyres for a Marlin Roadster
    3,407
    Do you know what the original donor car was. There were two different torsion bars fitted, the standard duty is 19mm dia.
    A Roadster is lighter than a Marina and the weight distribution is better balanced between front and rear, but it still means a stiff suspension is inevitable. Torsion bars used in Estate cars and commercials will result in an extremely harsh ride.
    Much of the comfort comes from the tyre sidewall deflection, the reason why tyre pressures are generally around 20psi, but that will vary as the sidewalls are different from manufacturers to manufacturer. It is not really possible to specify a correct tyre manufacturer as even their carcass design changes from year to year so deflections will vary along with tread patterns etc. Almost any good quality 185/70/13 will do. Try different tyre pressures until you find a good compromise. As for speed rating you would be brave to get a Marlin beyond 80 mph.
    I presume you have a Ford engine mated to a Type 9 style gearbox. Do you have fifth gear?
  7. #7 Re: Tyres for a Marlin Roadster
    486
    I used to run Millie’s tyres at about 18psi because it seems to give the best ride and handling. I then discovered that the manufacturer specified 22psi minimum. Those tyres are long gone and so is that manufacturer. I also notice that at 18 psi tyre wear is uneven. So these days I tend to use about 22psi. Although Millie is a Cabrio I think that checking for even tyre wear is probably the best indicator for appropriate pressure on any car.
  8. #8 Re: Tyres for a Marlin Roadster
    May 2012
    Gloucester
    92
    Finding what suits your drive varies, but once found maybe you, as I did two years ago go all round with hydrogen filled tyres the advantages are better with no refilling,ever ,unless you feel they need to be. Whether ho,cold,wet,dry, Sat in traffic or booting along the pressures stay the same so you know when you hit the brake s what to expect, also tyre wear is more constant.Berli owner used even in the snow. I use 19 psi.
  9. #9 Re: Tyres for a Marlin Roadster
    3,407
    Hydrogen? A puncture in one would certainly go with a bang!. I'm sure you meant Nitrogen.
  10. #10 Re: Tyres for a Marlin Roadster
    May 2012
    Gloucester
    92
    Spell checker.doesn't alway's get it right ? Nitrogen was what it was meant to say, still it's Xmas & had a few. Cheers
  1. Replies: 0
    Last Post: 29-07-2014, 07:33 PM
  2. Snow tyres for a Marlin?
    By andy-rogers in forum General Discussion
    Last Post: 26-10-2011, 08:28 PM
  3. Tyres
    By ggrum in forum Roadster
    Last Post: 12-10-2011, 07:36 PM
  4. Roadster wheels/tyres
    By dcunn in forum Roadster
    Last Post: 25-04-2010, 06:45 PM
  5. Alloy Wheels & Tyres for Marina based Roadster?
    By bbeech50 in forum Roadster
    Last Post: 04-06-2008, 12:17 PM
Tags for this Thread
