Marina Axle U bolts
  • Marina Axle U bolts
    Anyone know a source for long U bolts for a Marina rear axle with lowering blocks fitted - chasing a knocking noise have found that one U bolt is loose and the thread is stripped.... all the others have seized.....
    looking on the bright side it usually fails just as the weather improves in the spring.......
    Re: Marina Axle U bolts
    try here ... I'm sure someone will be along to tell you the exact spec in a few minutes.
    (http://www.grayston.biz/ubolots%20ex...ong%20page.htm)
      I have just prepared and uploaded a document for both Morris Marina and Marina based Marlin Roadster owners.
      here or there
      Getting information out of Grayston is impossible. Which standard length are they longer than? presumably 2 leaf springs, making them from Earlparts dimensions 6 3/8" I will update my sheet when I find out.
        Updated
