Hi all, iv had my car resprayed and the guys took off all my lights. Since then I have dipped and full beam on the main headlights, the ones on the wings show 12v across the wires bit as soon as I fit a bulb I have no power? Any ideas.thanks
Lights issue
Re: Lights issue
Is it just the front lights, are the rear lights working?
No power? To the whole car or just the front side lights?
It suggests to me you have a bad chassis connection on the headlight/sidelight circuit and the headlights are trying to use the sidelight as a ground return path.MOC member since 05/97
Re: Lights issue
If the chassis was resprayed, it's even more likely that the ground (-) connections are poor.MOC member since 05/97
Re: Lights issue
I think you should read this
The Laws of Brown and Branson for Marlin Owners
Sod has one, Murphy does and so do a collection of 19th century physicists so I don’t see why Andrew Brown and I shouldn’t.
Brown’s law states that whenever an electrical component on a Marlin fails to function the reason will always be a problem with the earthing of said component.
Branson’s law states that despite knowledge of Brown’s law and often prior demonstration of it Marlin owners will always spend time fiddling around with the live feed to a failed component before suddenly remembering Brown’s law and correcting the fault with the earth.
I can quote examples of these laws. I well remember stopping to help Andrew at the bottom of Stoney street on the Land’s End when his headlights failed. He was well into dissembling the live wiring to the lights and I offered my meter to test for volts. When I met him later he confirmed what we both should have known that the problem was with the earth.
The new addition to the Branson Marlin stable has had intermittent problems with its headlights. On the night before the Northern they wouldn’t work at all. I spent at least 45 minutes tracing the live feed from the switch to the fuse to the dip switch to the light until suddenly the penny dropped and I connected a jump lead from the negative pole of the battery to the headlight bar. This produced an immediate blaze of light and demonstrated Brown and Branson’s laws.
For those of you clever clogs who think you can defy these laws I would remind you that they belong to the same class as Sod’s law of which the complete definition is ‘ A piece of bread with butter and jam on will land butter and jam side down unless required to do so to demonstrate Sod’s Law. So next time a light goes out on your Marlin and you think I’ll show those idiots with their laws. You will spend the requisite 45 minutes undoing rusty nuts, losing them under the bench, getting everything clean with wire brush and emery paper and thoroughly restore the earth you will then find that what was needed was a new bulb. Don’t even think that by testing beforehand that you may avoid all the bother because even if the bulb works at the outset by the time you have sorted the earth it won’t. Trust me I’m a doctor.
Re: Lights issue
Originally posted by lil_red_roadster View PostLove it...we've all been there..!Mk2 SWB Marina Roadster with a 2.0L Pinto built in 1986
