The vent from my tank
  • The vent from my tank
    Hello
    or connects the gas tank wind pipe ?
    thank you
    Re: The vent from my tank
    Does your tank look like this?
    The fuel tank must be fitted with a vent (to permit release of a pressure build up) which does not exit on to the exhaust or into the vehicle or be situated at such a height that fuel would be likely to leak when the vehicle is driven.
      yes tank ford escort
      can you tell me where I can get him out
      thank you
        Can it not be placed alongside the suspension shocker etc , I located the vet on my Berly there, with the air exit about the same height as the filler, previously could only use about 80% tank capacity because of the sloshing about of fuel and it escaping via the breather.
          One of these valves at the top of the breather pipe should help. Peter
          Quality parts, spares & racewear for all Motorsport needs. Huge stocks supplied worldwide. Fast delivery. Professional service. Call us for technical help
            I think Jean is asking "how to remove the fuel tank" from the car.
            It depends on how the car was built! On some Mk 2 Roadsters the tank was fitted from below, on others from above. The build manuals were non specific, but suggest that the tank is fitted before the body.
            If it is fitted from below it should drop out once the clamp angle has been removed, if it is fitted from above, the whole rear bodywork has to be removed, for access, unless there is an easier method that I don't know about.
              no I do not want to change my tank
              I want to connect the hose to the exterrieur
              and do it in standards
              thank you
                photos
                  The only standard in the UK is, as already said "The fuel tank must be fitted with a vent (to permit release of a pressure build up) which does not exit on to the exhaust or into the vehicle or be situated at such a height that fuel would be likely to leak when the vehicle is driven."
                  The use of one of these would be a bonus.
                  https://www.merlinmotorsport.co.uk/s...breather-valve
                    I looped min around the top of the fuel filler neck and back down across to the passenger side of the car through a hole drilled low down in the back of the tub. There is a thread in the build diary section that has pictures from when I replaced my tank. I tried a non-return valve at the end of the pipe but it does not all the air to escape while filling so I couldn't get a full fill. My next upgrade would be to add a couple of small pipes to the filler neck to join the breather to the tank from and a non-return valve on the other so I can get the benifit of a full fill and have the non-return valve preventing fumes from escaping.
                      Have a look at post #25. It might give you some ideas.
