Stoneleigh 2016
  • #31
    Re: Stoneleigh 2016
    Many thanks for uploading the pics Scott
    • #32
      Re: Stoneleigh 2016
      Anyone know the sizes of the cut outs in the front rad panel !!!
      • #33
        Re: Stoneleigh 2016
        Re: Driveshaft
        Fit a tube that has had some holes drilled in and slide onto the broken 'X' part of the shaft. Must be short enough to clear the joint ready for sliding back over later. V the separated joint but keep the little turned shoulder as this helps with your shaft alignment, push them back together. Weld to the level of the OD of the driveshaft (dress afterwards with a grinder or file if necessary). Slide the drilled tube over the newly welded joint and weld through the drilled holes. Then seam weld the ends of the tube onto the driveshaft as well (think collar band on a worm).
        Belt and braces approach.
        Hope this makes sense as it's late and I'm with wine.
        • #34
          Re: Stoneleigh 2016
          You are welcome, some of the pics have 130 views which makes it worth doing.
          • #35
            Re: Stoneleigh 2016
            Anybody got any pictures from Monday?
            I had a great time on the Sunday with my son and there was a good turn out of cars. I wondered if the turn out for Monday was any different / better. Anyone?
            • #36
              Re: Stoneleigh 2016
              Just got back from a weeks hol's and found your proposed repair method. Thanks for that. What I am a bit concerende about is that I think I should do the other shaft while I am at it but as they say, I can't see the join. How do I break the shaft deliberately
              • #37
                Re: Stoneleigh 2016
                just a few random photos from Stoneleigh that i took. sorry i didn't get all the roadsters in. IMG_0522.JPGIMG_0523.JPGIMG_0525.JPGIMG_0526.JPGIMG_0527.JPGIMG_0528.JPG
                • #38
                  Re: Stoneleigh 2016
                  Nice, thanks for posting.
