Marina dash
This topic is closed.
    Re: Marina dash
    Originally posted by tony.stott2 View Post
    hi Adrian,
    so how will you finish the bottom edge, just plain, hockey stick , veneer etc? - curious as i'm about to redo my dash in the berly!
    I am going to see what I can do on a spare piece of wood with some veneer tape I have bought but if that doesn't work I will go plain.
    When it's fitted you can't really see underneath but I would prefer to do it properly, let's see how it goes.
      Re: Marina dash
      OK decided to go with some outdoor varnish for the edges as 1. You can't see it anyway and 2. The edging strip looked naff
        Re: Marina dash
        ok, thanks for the update!
          Re: Marina dash
          New question.
          I am using the original dials from a marina.
          I am also using the original multiplug.
          I have wired all but the RED/WHITE cable.
          Looking at all of the diagrams I have I can't, for the life of me, find what this is for.
          Any ideas anyone???
            Re: Marina dash
            HI Adrian - is it definitely red with a white stripe not white with a red stripe? And is it the loom which came with the donor car?
              Re: Marina dash
              Hi Cameron
              It's the original wire that was cut off when it was removed from the doner Marina.
              Once I know I can either ignore it or match it up with the new loom.
              Sorry definitely red with white stripe.
                Re: Marina dash
                On a Dolomite which uses the same Lucas system red with white stripe goes to illumination for the cigarette lighter socket comes off the red for the side lights.
                  Re: Marina dash
                  Now I'm sitting down I will have a look.
                    Re: Marina dash
                    Nope still can't find it.
                    The lose lead on the left is the offending item, it is mainly red with two white stripes
                    See picture below.
                      Re: Marina dash
                      According to BS-AU7a the British standard colour codes for vehicle wiring used by Lucas in the Marina claims that red with white stripe wires are used for
                      Sidelamp fuse to right-hand side and rear lamps.
                      Sidelamp fuse to panel light rheostat
                      Fuse to panel light switch or rheostat.
                      or
                      Fuse to fibre optic source.
                      White with red stripe is Starter relay or ignition or a bulb failure unit.
                        Re: Marina dash
                        or
                        Your right regarding the white with red stripe and all the wiring diagrams have the sidelamps as red/green to fuse and red to lamp.
                        I will leave it out for now, connect everything up and see what doesn't work.
                          Re: Marina dash
                          Hi Adrian, do you have a red/green wire There should be one in the multiplug for the instrument panel lights. If there isnt one it may well be that yours has been wired in with the red/white one. Red + stripe wires are generally associated with lighting circuits.
                            Re: Marina dash
                            Hi everyone
                            Now I know this is a big ask but has anyone else used the original marina multiplug on the back of the original instruments with a tacho?
                            If so can someone take a picure of the plug and the cables connected to the original cables.
                            Long shot I know but it just isn't the white/red cable that isn't listed on the wiring diagram but it also has a purple which is not listed to be connected to the multiplug.
                            • #29
                              Re: Marina dash
                              Just home after a few days away.
                              Have you looked at the diagram pics I put up in members area a while back, shows the WH/RD from starter motor to ignition switchery/instrument panel.
                              Haven't yet unlocked the garage but will look later at the spare loom bits I have and try to pic for you
                              Phone me if you like
                              • #30
                                Re: Marina dash
                                Purple is used for accessories powered direct from the battery, fused or unfused, that do not pass through the ignition switch, so horn, interior lights, boot light, car radio memory etc. anything that you might want powered when the ignition is off.
