Marina dash
This topic is closed.
  • #31
    Re: Marina dash
    1) On my car the WH/RD from starter is thick (as you would expect)
    2) Wires on this plug are : 1 RD/WH 2 GR/BK 3 WH/BR 4 GR/WH 5 GR/PI 6 GR/OR 7 WH 8 BR/YW 9 WH/BL 10 GR/BL 11 GR/GY 12 BK
    Sorry, don't know which variety of Marina/Ital this was from but hope it helps
    • #32
      Re: Marina dash
      That's white with a red trace the wire Adrian is trying to ID is Red with a white trace, its got to be something to do with a lighting circuit.
      • #33
        Re: Marina dash
        The British standard BS-AU7 describes all the colour codes if not pin out numbers. Worth reading.
        • #34
          Re: Marina dash
          Cheers DC
          • #35
            Re: Marina dash
            Purple is used for accessories powered direct from the battery, fused or unfused, that do not pass through the ignition switch, so horn, interior lights, boot light, car radio memory etc. anything that you might want powered when the ignition is off.
            Again your right Steve but I have a cable coming out of the multi plug which is purple.
            Hence my question.
            • #36
              Re: Marina dash
              Thick purple is for headlamp - could it be something to do with the main beam light in your instrument cluster and power outward to the lights ?
              Apart from the purple, do the other colours match up to my pics above ? What is the terminal number for the purple - is it 7, if so that is white on my pics so
              what does that say ? White in my diagram is from coil to ign switch and to voltage stab.
              I wonder if the RD/WH or WH/RD is something to do with the Reverse auto inhibitor (noted as Reversing Gizmo on my uploaded diagram). Dunno, I've just got simple wiring to my Reverse light
              • #37
                Re: Marina dash
                I know I am colourblind but headlight circuits according to BS-AU7, the standard Lucas colour code, are Blue, definitely not purple.
                Purple as I have previously described.
                • #38
                  Re: Marina dash
                  Hi Guys,
                  Just been pulling my wiring to bits for, what it is worth purple wire on mine is the horn if that's of any help.
                  Graham
                  • #39
                    Re: Marina dash
                    Originally posted by fouter View Post
                    Hi Guys,
                    Graham
                    I am still right with my first choice then!
                    • #40
                      Re: Marina dash
                      On one car anyway, can't vouch for the others!!!
                      • #41
                        Re: Marina dash
                        Hi all
                        First of all many thanks to all those who have helped by contributing to this thread.
                        I have now found a manual that has the pin numbers for the multi plug, well hidden in my view, and have attached a picture of said page with the numbers highlighted and top left the corresponding cable colour.
                        You never know it may help someone else down the line.
                        • #42
                          Re: Marina dash
                          Beware!
                          There are several different wiring diagrams from different Marina/Ital models, and several different pin-out patterns, but the principle destination of a cable is always defined by its colour coding according to BS-AU7. You were only asking about colours, so that is what was answered, for answers about pin-outs, we would need to identify the donor loom.
                          What you have there is information from a Haynes manual. Not so sure the Left Hand Drive version will help too many people.
                          For other readers, here are clearer, larger diagrams, complete with the item number key and colour code key.
                          The multi-plug pin-out numbers are probably the smallest type on the diagrams. Magnifying glasses at the ready!
                          Scanned images from Haynes, here or there 5.3mb 13 pages
                          Scanned images from the Workshop Manual V9, here or there 5.3mb 22 pages
                          • #43
                            Re: Marina dash
                            Beware!
                            Steve
                            I don't use k and s enough to keep renewing my access.
                            Can you give access again please.
                            Otherwise the information is neXT to useless for me.
                            Ps the left hand drive is only there because of the way I took the picture, we can't all be expert photographers.
                            • #44
                              Re: Marina dash
                              Steve
                              This is the Haynes manual I have used.
                              Apologies in advance for the poor photography
                              Remember mine is a 1978 1.3 marina doner.
                              • #45
                                Re: Marina dash
                                Just download the documents that look like they might b of interest and store them in a convenient place
